Networks Belkin PCI Wifi Card Bloated Boot Time?
Discussion in 'Hardware' started by empyrean, 11 Dec 2006.
  1. empyrean
    empyrean What's a Dremel?
    20 Sep 2003
    After installing a Belkin wifi card, XP Pro's boot time has increased quite a bit... and it takes 2-3 minutes before XP's Wireless Connection icon pops up and starts connecting to the network (which takes only seconds once it starts).
    I've used numerous other Wifi cards on other systems without running into this problem. Any way to make the Belkin load faster?
    System is in signature.
  2. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    Not overly sure about the PCI version, but I know they did a 54g pcmcia card, which not only destroyed load time, but also kept the processor running at 100%.
    Only thing I can suggest is going to msconfig, disabling any belkin services, and relying on the windows config utility
  3. kenco_uk
    28 Nov 2003
    Try setting it to a static ip address instead of dhcp.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Mine doesnt add any significant extra boot time..
  5. empyrean
    20 Sep 2003
    Cheers, found a service I thought I'd cleared out and it did the trick... card connects < 5 seconds now.
  6. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    What service was it?
    I have a Airlink card that if I let the wireless util run at bootup, it takes forever. I prefer to just run it when I'm using the wireless..
  7. empyrean
    20 Sep 2003
    I believe it was the Atheros Configuration Service.
