Hardware Belkin Powerline AV Network Adapters
Discussion in 'Article Discussion' started by Tim S, 27 Dec 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Neat. I'll wait for the prices to come down though, still a bit too steep imo. But if a kit like this hovered in the $50 range I'd happily pick one up.
  3. Teq
    Teq What's a Dremel?
    11 Aug 2008
    I had my Xbox attempting to run a media center extension via 802.11g and it couldn't even cope with SD signals, plugged this kit in (which just works btw - refreshing that there is no fiddling around to get it functional) and was instantly able to play hd media across the connection, no trouble at all, not only that but I am now also able to host 8 player games of Forza with friends and they have very stable connectivity to me. Sure it doesn't beat my cat5 to my main PC's (2 gaming rigs and a HTPC), but it makes anything other than the new 'n' standard wireless networking look absolutely appalling, my only small issue with them is that the first batch that arrived developed a fault within a couple of days.
  4. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    at 30quid i'd pick up a pair
  5. frojoe
    frojoe What's a Dremel?
    17 Dec 2008
    We have been using this setup(not Belkin) in our house for almost a year because one computer is out of wifi range. They are a generic provided by the ISP for 30 USD a piece. The box claims 85 MB/s, and that's probably a complete lie, but it has been plenty fast for browsing, and 100 percent reliable to the other end of the house. It's a great technology for this sort of thing. It would be nice if the price would come down a bit more though.
  6. Sark.inc
    Sark.inc What's a Dremel?
    9 Dec 2007
    anyone have a good link to how this stuff works?
  7. Glider
    Glider /dev/null
    2 Aug 2005
    Does this also extend your network to the outside world over the power cables?
  8. SkOTT
    SkOTT What's a Dremel?
    23 Jun 2008
    Nope, attenuation gives the signal a maximum range, your neighbours will be lucky to even see it, let alone connect.
    Wikipedia knows all.
  9. Glider
    Glider /dev/null
    2 Aug 2005
    The maximum range could be closer then you imagine, think about apartments... I don't like the feeling of giving physical access to my network to my neighbours...
  10. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    simple router mac address filtering would take care of that though.
    I do like this idea, even if it's to allow the optimum positioning of a wireless router. I see this tech being very useful in a few years once it has matured and improved a little more. Have most pc's connecting through the power lines, then have a wireless router for laptops, iphones etc.
    Good review BT, nice to see the tech has improved :)
  11. barrkel
    barrkel What's a Dremel?
    31 Jan 2007
    'm/s' is a unit of speed (metres per second), but I seriously doubt that the power-line transmission was that slow (24 metres per second).
    'ms' is the prefix I believe you were looking for - milliseconds.
  12. *Y@h00k@*
    *Y@h00k@* What's a Dremel?
    11 Nov 2003
    I use a kit similar like this from Devolo. It's got a config utility which let's you set a password, so no one lese will be able to connect to it, and they also have a model which will give you wireless access.
    Great stuff
  13. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Similar devices on the market all give an on-the-fly encryption option which according to reviews doesn't slow them down much.
    But as it's you, the Linux fan,
    :duh:
    :lol:
  14. ch424
    ch424 Design Warrior
    26 May 2004
    Surely you would have that same problem with WiFi?
  15. Skill3d
    Skill3d Minimodder
    29 Sep 2005
    You can't use these things if there's a dimmer on the same power group...
  16. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    so I wasnt sure if it was mentioned as I skimmed the "review" but how does this effect your power, wont it dirty your power even further?
  17. OleJ
    OleJ Me!
    1 Jul 2007
    That would be "write/copy/read".
  18. sandys
    sandys Multimodder
    26 Mar 2006
    Been using the 200Mbps ones from Netgear with similar results, been running for over 2 years no problems whatsoever, so much better than wireless for me, as a warning they don't work in all houses which makes the outlay a little risky if you have problems returning it
  19. Impossible
    Impossible What's a Dremel?
    23 Jun 2002
    I only had chance to skim read the artical, but wont the ethernet ports on these have to be GbE to be able to meet there maximum 200Mb/s?
    Or are they 100Mb ports and the powerlines can do a 200Mb network, eg to allow more than three computers hogging the bandwidth.
  20. andyp06
    andyp06 What's a Dremel?
    30 May 2005
    I've been running 3x200Mbps Netgear Powerline plugs as part of my network for about a year, as my WiFi was drowned out by the 12 or so other users in the neighbourhood. I love the Netgears as they give a consistent 85Mbps+ & the data dropouts I had with WiFi are no more. They work with dimmers but do need to be plugged into the wall socket, not an extension. The only thing that stops them is the electric meter, so the neighbours can't snoop, which is another bonus. Setting up secure encrypted WiFi was a royal pain which I don't need to do with the Powerline's, they are quite literally 'plug & go'.
Tags: Add Tags
