Hardware Belkin Powerline AV Network Adapters
Discussion in 'Article Discussion' started by Tim S, 27 Dec 2008.
  1. Sark.inc
    Sark.inc What's a Dremel?
    9 Dec 2007
    how does that stop them?? wiki says nothing!
  2. steve_hb
    steve_hb What's a Dremel?
    28 Dec 2008
    how does that stop them?? wiki says nothing![/QUOTE]
    Often separate houses will be on different phases from a 3-phase supply or will have a return noise filter on the line side of the power meter, these tend to interpret as noise and smooth out the high frequency signal from the networking gadget.
  3. Solidus
    Solidus Superhuman
    26 Dec 2005
    Are these a good option for gaming then? I have my xbox 360 connected via wireless adapter and drilling a hole or two for a Cat5 cable is really not something I want to do. If this is sufficient - I may consider it - Could you guys perhaps run a test of some sort to see how it runs? if it works well?
  4. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I have 4 of the BT Vision ones - They're also 200Mbps, although MCB's (ie from the upstairs ring to the downstairs ring) play havoc with the speeds. It dips to ~14Mbps sometimes. Mind you, that's still better than the flaky wireless we get.
    Speeds are also dependant on transient load. A large inductive load, like the hoover or washing machine, will also cause speed blips, but it's not too bad generally.
  5. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I cannot see these working in my house, the main problem being the water pumps which are a large enough load to dim all the lights.
    However, despite being quite a big house, we have manage to get a wireless signal all over it and that is only with g. Its not like we have particularly thin walls either :)
    Anyway, the internet is always going to be the slowest link and I can't persuade my parents to let me put in any computers that aren't strictly necessary... the BBC iplayer laptop is hanging on by pretending not to be anything to do with the TV :D
  6. andyp06
    andyp06 What's a Dremel?
    30 May 2005
    You should get the equivalent of a 100Mbps wired network if your wiring is good & you get a 200Mbps Powerline kit, so this is ideal for gaming & downloading movies. Mind you, I've found I get 85Mbps from one socket & 100Mbps from the one next to it, so simple changes to your basic mains circuit have a significant effect.
  7. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    Good thing to add another wifi access point in the house ^^
    Their other problem is that they send a MHz signal through UNSHIELDED wires, and thus your whole wiring becomes an antenna, which is worse than wifi interference wise.
    I laugh at those who use this because wifi is "too much radio waves"...
  8. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Thanks for the review guys, just bought one of these yesterday (at inflated Argos prices unfortunately), but it works brilliantly - no more flakey wirless connection. :thumb:
  9. gibber
    gibber What's a Dremel?
    1 Dec 2008
    I've been using powerline networking in my house for a few years. Its a perfect replacement for wireless which has never worked more than a few meters away from the AP for some reason. Its a bottleneck when moving large files, but I dont use my network for that anyway.
  10. Steve Redway
    Steve Redway What's a Dremel?
    30 Apr 2009
    Power Line Adapters (PLAs) whilst seemingly a good solution to home
    networking are essentially a very poor technology. They pollute the
    radio spectrum, interfere with your neighbors’ radio (preventing
    reception of Short Wave broadcasts) and do not adhere to the European
    EMC directives.
    They rely upon your internal house wiring to pass signals between
    units. Unfortunately, your house wiring is a good aerial and these
    signals go far beyond your house, many 100s of yards and in some cases
    get into external telephone lines and street wiring and have even been
    known to radiate from lamp posts. The units effectively become the
    same as an illegal radio transmitter.
    The government and OFCOM know the problems regarding PLAs and will
    respond when complaints are made by your neighbours, by removing the
    devices, so please ensure that the retailer has a sale or return
    policy. In a lot of cases involving BT, this translates to BT
    replacing the PLAs with CAT5 cabling.
    Home networking has a perfectly good wireless system based on the IEEE
    802.11 standard (see http://en.wikipedia.org/wiki/IEEE_802.11). This
    is commonly called WiFi and operates at frequencies (2.4GHz) that do
    not interfere with other equipment. It is legal, adheres to all
    European EMC directives and allows you to transfer your broadband and
    gaming system throughout the house.
    There are campaigns afoot both at local and governmental level to have
    PLAs removed from the shops and banned. Australia has already taken
    steps to ban PLA devices.
    So in reality, they are not such a good idea after all.
  11. badders
    4 Dec 2007
    Err, no it doesn't. It allows you to network PC's in the same room (just), but any further than that and my (apparently lead-lined) walls block the signal.
  12. Bayaz
    Bayaz What's a Dremel?
    4 May 2010
    All new houses should be required by law to have Cat5e connections in every room! My internet connection is downstairs and my desktop is upstairs. I bought a wireless N adaptor but the signal was very low so my only choices left are powerline or install cat5 cable.
  13. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    well ya your signal is low, your signal strength is in the horizontal plane not the vertical, what you need to do is run a cable straight to the second floor and put an access point and then your whole upper floor will get better signal.
Tags: Add Tags
