Networks belkin router issues
Discussion in 'Hardware' started by gbeeby, 11 Dec 2007.
  1. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    sup lads, been a while....
    well.. i bought a new router a few days back, which i belive to be the.... belkin f5d7632uk4a
    i did the usual; type in the username, password, MTU.... and guess what.. no connection !
    (excuse me while i get my stab proof jacket) i'm on AOL..... i learned that with the settings typed into the router config page i can go into the AOL program and connect as if i would with a normal modem, then the internet is fine, connected. but i dont want to have to remind myself that i'm on AOL everytime i want to connect to the internet.
    my first guess is that iv'e got something wrong in the settings.. so ill post them here so you can point and laugh if i have.
    Connection Type = PPPOE
    Username = me@aol.com
    Password = *******
    Retype Password = *******
    VPI/VCI = 0/38
    Encapsulation = LLC
    MTU = 1450
    and ideas boys, anything.... treat me as im stupid if you like (yes it is plugged in smart arse)
    xgb
  2. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    Belkin Support Page - AOL
  3. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Is it plugged in?
    Sorry, I had to. Your fault for giving me the idea though. ^_^
  4. gbeeby
    6 Dec 2005
  5. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    did you drop the MTU 1400?
    have you got the latest firmware?
  6. gbeeby
    6 Dec 2005
    yes,yes...................yes, its plugged in
  7. gbeeby
    6 Dec 2005
    cheers guys, sorted now...............wasn't plugged in, jks..... the connection type needed to be PPPOA
