Guide bending plexi
Discussion in 'Modding' started by cr3ativ3, 27 Apr 2007.
  1. cr3ativ3
    cr3ativ3 What's a Dremel?
    24 Apr 2007
    hi there!
    i'd like to know your opinion about bending plexi..
    i know that you have to warm it up(a lot), so it can be bendable without breaking..
    'd like to know witch tools i have to use, and for how long i'll have to warm the plexi so it can be bendable..
    that kind of things that a noob @ plexi bending needs to know..
    regards
  2. IanJackson
    IanJackson Photographer & Modder
    22 Mar 2007
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    well if you a slow internet connection (like me) i can just tell you
    here is a clipping from an article I'm writing for an another site, tell me if you like it
  4. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    You should mention that the heater element is simply a long piece(s) of resistant wire
  5. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    You would need more heat then a piece of nichrome wire would put out. The heating elements that ive seen used in hot-strips for bending acrylic were more similar to the elements used in electric ovens or water heaters then just regular nichrome wire.
    If you're using a heat gun for a long straight bend, I would clamp either side of the acrylic between blocks of wood.
  6. cr3ativ3
    24 Apr 2007
    thank you for all the answers.. :thumb:
    now i am aware of bending plexi is also possible at your oven...
    am i sure ?
  7. IanJackson
    22 Mar 2007
    Do u mean useing the top burners or inside it because it would be hard to use the inside... lol
  8. cr3ativ3
    24 Apr 2007
    sorry, i'm not english os american.. e didn't get it... :confused: :duh:
    regards
  9. IanJackson
    22 Mar 2007
    I mean't like to u have an oven that u like bake stuff in? well i mean't like use a top burner which is wat u like boil water on but its alright if u didn't get it! :hip:
  10. cr3ativ3
    24 Apr 2007
    hm.. you mean i can use the oven, but only with the top burner on ? if not, nevermind :thumb:
  11. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Get a heat gun and use something straight to guide straight bends. It's easy and heat guns are $20
  12. koolkidd
    koolkidd What's a Dremel?
    26 Nov 2006
    basically what i did was make a jig so once "melted" it could be held in place till cold. so i heated it in the oven till it went floppy, threw it in the jig (in my case an arc) and held it outside in the cold. it worked a treat.
