I looking for a tool to bend 1mm steel and 2mm aluminium sheets at 15° to 90°, would this be what I'm looking for ? http://www.grizzly.com/products/G0557/ if it is, do anybody know what they are called in french or german ? thanks !
that's just what I need. I'll probly make one someday. edit: not all bending brakes will have that feature, but you should be able to find one that does. they are just alot more money.
abkantbank in German. Froop - where have you seen them for €30 over here? Any chance you can let me know so I can get one, can't find them anywhere I live for less than 120 and that's the small table top models.
Yes, that will work - I have the same one, and bend pretty nice alu-sheeting with it - see last page in my HP Blackbird Project log. They are rated for I think 1.2mm aluminium only, buyt, if you bend slowly, and carefully, and not bigger than around 300mm, you can bend 2mm aluminium.... Enjoy edit: In english it's called either press-break, pan-break, bench-break or a sheet-metal bender.
i have a nice box and pan brake i snagged for $300 on craigslist. its sweet- 16 gauge and 48". talk of a steal. The one you linked will be able to make boxes- any will that have those removable teeth. Its limited to the kind of box you can make, but worst case scenario you can re-design the box and fold it in a different way. Cheers!!
