what is a good 120mm radiator that i could (if possible) fit on the inside of my shuttle, or mount on the back.
i did research and i could not find an answer to my question of what a good one is and wether it can fit inside a shuttle. and i will continue to post in the forums with my posts belong in. you should consider not flaming.
Fanatik is merely referring to is the forum rules: No cross-posting! And he is right on the research bit: most websites/shops selling radiators will mention their detailed dimensions in mm. If you have a Shuttle, it is only a matter of taking some measurements and seeing what space you have to work with. If you don't have a Shuttle yet, now is the time to get one to aid in your planning process. Also, look in various modding forums for modded Watercooled Shuttles (Google for "watercooled shuttle PC" for instance) and see what others have done!
i have. ive seen ones with rads all over ones with them inside but normly the ones on the inside are in setups with tubing smaller than 1/2 inch. im trying to see if there is a 120mm rad that can be complietly contained along with my pump and res.
