Graphics Best 15 quid ever!
Discussion in 'Hardware' started by Highland3r, 9 May 2005.
  1. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Went to a computer fair on Saturday, and grabbed a 9500 NP 64mb card for 15 quid. Had a feeling it'd softmod to pro, and it has done. Grabbed a card with 3.0ns mem too, so with a little tweaking (ie vmods) it should fly.
    So, stock, ran a quick 3dmark to start off with. (bear in mind this is a 24/7 OS so is full of bloatware)
    Stock run
    After a little overclocking, it reached the heady heights of 410/310 still totally clean through 01
    Unmodded max
    All in all not bad for 15 pounds...
    Then came the softmodding. Took a fair hit on core clocks due to the extra 4 pipes, but nothing a little cooling and some volts cant fix... 350/310 was ~ the max, needs a little better cooling and should go further.
    Modded score
    Its not all about benchmarks though (they do show ~ a 1/3rd extra performance though) its been sat running cs source for the past 2 days totally happily. 1024, Maxed details in source, no aa or af though. Sits ~ 60 fps on nearly all maps with the occasional drop a little lower.
    Mighty impressive for a 64mb card, thats getting on for 3 years old now. Its a pitty they didnt have any of the 128mb versions, these often mod up to 9700 levels, adding 256bit memory bus.
  2. Tim S
    Tim S OG
    8 Nov 2001
    ooooooo, nice. :)
    If only it had 128MB memory though, you might kill 19k then.
  3. Highland3r
    25 Jul 2003
    19 should fall, just need a 2k install and DX8. VGA silencer should help a little too ;) Aiming for 20k with this card (and 4200 which is sat here too) in the month off after exams ;)
  4. webbyman
    webbyman Hax.
    7 Oct 2004
    :baby: that's a great score :D one to be proud of with that card... especially for £15 :p
  5. TMM
    TMM Modder
    12 Jan 2004
    niiice. :eek:
  6. Highland3r
    25 Jul 2003
  7. TMM
    TMM Modder
    12 Jan 2004
  8. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    Not bad mate ;)
  9. alastor
    alastor Minimodder
    6 Sep 2004
    Wish mine would softmod, only manage 15.3k at 410/330 with 4 pipes :waah:
  10. Highland3r
    25 Jul 2003
    Is it on L shaped memory?
    Installin 2k on the Dothan as we speak, hoping for a little more from this thing ;)
  11. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Bloody hell, 20k on a 9500. :jawdrop:
    I won't tell you about the best £15 I spent
  12. Highland3r
    25 Jul 2003
    Wasnt summit dodgy was it? ;)
  13. alastor
    alastor Minimodder
    6 Sep 2004
    Yeah it's the L-shaped 256-bit 128mb memory one, just no display at all with the softmod drivers installed :(
    Good luck with a fresh 2k install and all that nice Pentium 3 power :D
  14. Highland3r
    25 Jul 2003
    Try with the hacked ati2mtag.sys file for the cats you have :) Its a little more work, but runs like a dream :) Easy to reverse to :) Just swap file back and update the cards drivers.
    2k was a no brainer :( Not a single increase anywhere, despite re-installing twice :( Added another XP install, and it seems a little better... Need to play about with drivers, but cant get close to the other days run :(
    Card needs vmods/better cooling :(
    <edit> lol its a sea of blue smilies /me counts 7...! </edit>
  15. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    Fecking nice scores, puts my 9700PRO to shame :(
    Have you got any hints on how to get my 9700 PRO working any better, i currently get 16K using 360/330 clocks, with a VGA silencer. Are there any software tweaks or things to play with. I didn't manage to get all the hard thermal glue used to stick the original heatsink on with, could this be a problem and limit the overclocking?
  16. alastor
    alastor Minimodder
    6 Sep 2004
    Any idea if the hacked file works with the Omega drivers? Using Omega 2.6.25a at the moment (Cat 5.4), or should I just go for the official Cat 5.5 and patch those?
    Thanks in advance
  17. Highland3r
    25 Jul 2003
    Dont see why it wouldnt alastor :) Give it a shot and try :) Just grab the ati2mag for the 5.4 cats (http://www.techpowerup.com/softmod/ati2mtag.22141.zip)
    tank_rider, have you got a ORB 3dmark compare? Just choose custom detail settings, and drop them all to performance. This will give a small boost. Can also play with the order you run tests in for more performance.
    360/330 isnt too bad for a 9700, how much of the gunk was left? Might be worth setting on it with some alcohol and a credit card. Its a PITA to get off, but helps contact loads.
  18. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    bah silly cpu based benchmark...
  19. tank_rider
    3 Feb 2005
    Highlander, heres my compare link.
    I dropped the setting to performance and got about an extra 200.
    There is still quite a lot of gunk on there so will give getting that off another go. Would it be ok to use white spirit, or meths?
  20. Highland3r
    25 Jul 2003
    Both white spirit and meths leave a slight residue, so either ensure its completely removed, or wonder down to a chemists and get some "isopropyl alchohol" that'll shift it no probs :)
