A/V best 2.1 speakers for roughly £40-50
Discussion in 'Hardware' started by audiophobe, 22 Nov 2004.
  1. audiophobe
    audiophobe What's a Dremel?
    22 Nov 2004
    hi im looking for 2.1 speakers roughly £4-50 price range?
    will these play music at a decent enough quality? if not possible could stretch a little bit
  2. audiophobe
    22 Nov 2004
    ok actually im gonna be getting a new computer so gameing in the future. a 5.1 would be a better idea. and £80 is the limit.
  3. dom_
    dom_ --->
    4 Jan 2004
    no offence but £80 on a 5.1 system is not enough. You will end up with something that sounds terrible and has no bass. Can you not up the budget?
  4. audiophobe
    22 Nov 2004
    well what is the cheapest good quality 5.1 system you recomend.
  5. dom_
    dom_ --->
    4 Jan 2004
    no idea im not too clued up on that end of the price range im afriad.
    but just try and spend the most you can and get the best you can. you will be greatfull when you listen to music and it sounds real and playing in games you crap your pants, also you feel in the film while watching dvds :)
    its worth it :D
  6. fathazza
    fathazza Freed on Probation
    20 May 2002
    /me looks around for M[at] ::worried::
  7. da-dude
    da-dude What's a Dremel?
    11 Mar 2004
    i have a set of logitech z-640's for £50 from ebuyer
    il admit, i dont know much about speakers, but i do know these are an impressive set for the price - bass is rich and great with movies, and the srurround sound is better than i expected - especially when i realised i hadnt plugged the rear two speakers in :wallbash:
  8. audiophobe
    22 Nov 2004
    ive seen creative 5300s recomended on this site? what about them? or logitech thx ones that were 100-150. and can be picked up on ebay for a bit less.
