Windows Best 3rd party "Media Center" style interface, without OS upgrade
Discussion in 'Software' started by RickDawson, 14 Jan 2010.
  1. RickDawson
    RickDawson Minimodder
    29 Mar 2006
    I'm running my old desktop, and would like to add an interface in front of Windows XP home. It's been a long time since I looked at 3rd party interfaces, so what would you now recommend?
    I have a 3rd party Media center remote, and an Antec 'Veris' infra red receiver.
    I'm looking at all options (except OS upgrade)
  2. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Have you looked at XBMC or meedio, It really depends on what you need from a 'media center'.
  3. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    +1 on XBMC or try Boxee
  4. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    XBMC if not after TV tuner use, I use it on 2 original xbox's and my PC, it's that good it converted a non believer and his parents to use it due to the ease of it and the varied skins
    worth a try
  5. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    +1 to all recommendations for XBMC. The only flaw is the lack of TV Tuner support, but other than that it's a brilliant piece of software.
  6. RickDawson
    29 Mar 2006
    xbmc it is now, easiest to use and it works out of the box.
    just need to get it to read *.wtv
    only solution (so far) is to convert to *.dvr-ms (right click *.wtv and select convert to *.dvr-ms)
    any advice?
    how to automate, or change the default recording format in windows 7 ?
  7. Byron C
    12 Apr 2002
