Displays Best 52" screen?
Discussion in 'Hardware' started by rainbowbridge, 12 Feb 2010.
  1. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    Reception area with a high end workstation, + fx3800, Will be running a standard 22" lcd and also a 52" on a wall mount.
    Whats the best 52" for wide viewing angles, long on periods obviously.
    Bugdet not an issue as long as good reason can be stated for screen.
    I dont see "screens" as such only tvs above 30"?
    cheers
    rb
    Edit: Im on trusted reviews at the moment, http://www.trustedreviews.com/filte...lter=86&manufacturer=0&submit.x=16&submit.y=8
  2. Jux_Zeil
    Jux_Zeil What's a Dremel?
    30 Apr 2009
    I have a Sony Bravia 1080p EX series TV connected to my nVidia 8800GT through HDMI and I love it. Cost a lot at the time, £5800, but it's worth every penny as I have no viewing angle probs ace contrast with no edge fade. In fact the only let down is with badly made/transmitted Freeview programs. The upscaling sometimes looks bad on adverts lettering. But who really cares about that really?
    I'm sure the tech has advanced enough to make mine look dated now but if I were to upgrade I know what make I'd go for. :thumb:
  3. Krikkit
    21 Jan 2003
    At that size you won't find any consumer monitors, only LCD-TV's. Jux has hit it pretty much spot on, I'd go for a 1080p TV, because the cost of a proper monitor is liable to be absolutely enormous.
  4. rainbowbridge
    26 Apr 2009
    ive just put forward a Nec MultiSync LCD5220, its rated as a public display screen, I dont know if thats due tot he bezil size or its inneards
    Edit: Just seen it comes in a "protective glass version" for an addtional few hundred pounds.
    I asked what the budget was and told it does not matter, it needs to be jusified. See what feedback I get with the above 2.5k one.
    Double edit: The 22" is a 2243BW which is a samsung, be interesting if sammy do a 52" wide viewing angle etc.
    Triple edit: Looking at the Samsung LE55B650T2W 55 inch LCD Television 1920 x 1080 (Black)
  5. Jux_Zeil
    30 Apr 2009
    Just had a look at it and although it's not a bad screen, the response time is actually longer than my Sony. Not a lot but it's always a case with PC screens that the lower the better.
  6. Guest-44432
    Guest-44432 Guest
  7. Jux_Zeil
    30 Apr 2009
  8. Guest-44432
    Guest-44432 Guest
    I hope not, as I plan to keep it a couple of years.
    Simon
  9. bagman
    bagman Minimodder
    18 Apr 2009
  10. Elton
    23 Jan 2009
    The government won't ban Plasmas...well not yet anyways.
    However with that said, perhaps you can find an old Pioneer PRO FDH1, I have one and it's absolutely gorgeous.
  11. Jux_Zeil
    30 Apr 2009
    Oh they probably will in Great Britain because they are bad for us and the enviroment, we wouldn't want to hurt ourselves now would we? :rolleyes: Bloody nanny state!
