Graphics Best 9800pro for NOT overclocking / modding
Discussion in 'Hardware' started by Mord, 14 Jan 2005.
  1. Mord
    Mord What's a Dremel?
    7 Mar 2004
    Recently I had a 9800pro die on me, still pissed at it. So im going to buy myself a new one and not make any alterations to it what so ever, so if it does die i can RMA it.
    Question is, whats the best make of 9800pro to use as stock? I meant the
    HIS ATI Radeon 9800 Pro 128MB DDR IceQ Seems to have the best stock cooling (since i dont want to change stock heatsinks) would that be a good buy? Bareig in mind I dont want to spend more then £150.
    (link) http://www.overclockers.co.uk/acatalog/9700_to_9800_Series.html
    Thanks once again,
    Mord.
  2. Mord
    7 Mar 2004
    ALso on a side note, no where seems to have any currently in stock, ive tried,
    Ebuyer / TekHeds / OCuk / Komplette
    Any other suggestions?
  3. malfunction
    malfunction What's a Dremel?
    5 Jun 2002
    For the same kind of money you could get a 6600GT. Not a huge difference in performance but you might as well. FWIW I've just had a 9800 Pro die - and as I'd added an arctic cooler and flashed it to an XT I can't RMA it either... Seemed like the arctic cooler (V4 - 'ATI 1') unscrewed itself and the core burnt out. Though I doubt I'll be able to convince arctic cooling so that's £125 down the drain. Talking of which (£125) if you're set on a 9800 Pro www.lowestonweb.com have them... As for the 6600GT www.dabs.com and www.tekheads.co.uk had the best prices on AGP versions last time I looked.
  4. Hobnob
    Hobnob What's a Dremel?
    11 Jan 2005
    People keep asking this question. Only the bundles vary, all 9800 Pro's are clocked the same.
  5. Mord
    7 Mar 2004
    But the HIS Exlaibur comes with a VGA sliencer fitted as stock.
    Also I thought the 6600GT was aful for drivers?
  6. malfunction
    5 Jun 2002
    I have heard that nvidia have had some issues but nothing major - and you can only assume they'll be sorted with time. Of course the other option is to get a cheap placeholder card and wait until mid year before buying a socket 939 / PCI express rig (x800 XLs ought to be around 9800 Pro money around then I reckon)...
  7. Mord
    7 Mar 2004
    Done a bit of research into both cards, may take the plung and buy my first ever Nvidia :D
  8. Tim S
    Tim S OG
    8 Nov 2001
    did you know there's a graphics card forum? :worried:
