Modding Best adhesive 4 Neophane & aluminium??
Discussion in 'Modding' started by Supershanks, 16 May 2007.
  1. Supershanks
    Supershanks What's a Dremel?
    14 Mar 2005
    I'm planning on making a shroud for my rad & have some neophane which i want to use as a gaket. I'd like to stick the gasket to the aluminium shroud - what's the best adhesive to use.
    cheers
  2. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Ever try the Adhesive Tape of the Gods? :D
    Tape
  3. Supershanks
    14 Mar 2005
    thanks, never thought of tape :D
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    yeah double sided tape.
    I was going to mention epoxy resin, stick anything together! i glued my water block back together after the acrylic cracked, still in the machine faultless!
    or a few spots of super glue, i used it when replacing the gasket on my oil sump, holds it in place whilst i bolted the sump back on! :thumb:
  5. Supershanks
    14 Mar 2005
    Had played briefly with superglue on a fan gasket that was hard to mount on my raer fan without something too hold it. But when i took it apart a few weeks ago it didn't hold leaving marks i had to scrape off, mind u i'd onlty spotted the gasket enough to hold it straight till screws went thru.
    cheers will see what i can get tommorow from local diy :D
  6. kalm
    kalm What's a Dremel?
    6 Jul 2005
    Have you thought about using car gasket sealent.
  7. Supershanks
    14 Mar 2005
    got some evostick impact adhesive which has done the job.
    thanks
    now just got to get me greasy mit marks off :D
