Graphics best agp card
Discussion in 'Hardware' started by Drastik, 22 Nov 2005.
  1. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    ok i gave up on a pci card and decided to get a new mobo for 110 and a new gfx card. well i cant afford a pic-e card so im going with agp for now. i saw a fx5500 and a radeon 9550 which is better or more worth the money.. it will be for my media center
  2. Boswell
    Boswell Minimodder
    23 May 2005
    hhmm i dont think you need a very good graphics card for your media centre unless your outputting High Definition. Get whatever you can afford tbh (i could be wrong with this but im pretty sure im correct)
  3. Masterngc
    Masterngc What's a Dremel?
    30 Aug 2005
    go with a silent cooled gf6600 from gigabye.. they also have high def out
  4. westie
    westie What's a Dremel?
    31 Jul 2005
    You can get a 9800PRO for cheap now maybe more worthwhile getting one of them.
  5. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
  6. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    wha? softmod a 6200 to a 6600 thats like softmodding a 9200 to a 9800
    6800XT ***
  7. jaguarking11
    10 Dec 2003
    Actualy if you do a bit of reaserch you will find its the same core. At least the early revisions. The newer cores and the turbocache cores dont softmod because they are not the same core as the 6600. I have a softmodable 6200 to 6600. The problem is that the 6600gt relys on 900mhz-1ghz speed on memory and the vanilla 6600's and the 6200's donw oc their mem to those speeds so your mem speed would be 400-700mhz depending on your memory type and luck.
