Small Form Factor Best AM2 matx motherboard
Discussion in 'Hardware' started by axscpu, 23 Feb 2007.
  1. axscpu
    axscpu What's a Dremel?
    2 Jun 2006
    well as the title reads... which matx do you guys consder the best out there....it has to be matx :D
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I don't know about "best" but two AMD AM2 to look hard at are Abit NF-M2 nView and Asus M2NPV-VM. Both will run Aero Glass with the built-in graphics.
  3. axscpu
    2 Jun 2006
    those are the two I was looking at.... but I can't decide between them...
  4. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    nF-M2 nView
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Reviews of each at motherboards.org
    Get the manuals and check them out better. Depends what you want from the board. I'm seriously thinking of the Abit but there's not much in it.
  6. axscpu
    2 Jun 2006
    I went with the gigabyte GA-M61PM-S2 which is single chipset and was the only high model matx they had in the store.... I was kind of hoping they had the abit in stock... but it doesn't bother me much as its not going to be a performace pc but a server pc.... but thanks guys for the effort
  7. axscpu
    2 Jun 2006
    at the end I'm returning the gigabyte motherboard as its not compatible with my memory
    (well actually it does not allow me to set the timing or the voltage on the memory) which means i'm losing that extra I paid for, in buying the kingston hyper x...... so hopefully I will wait for the abit... which is the only on that allow memory tweaking
  8. sackingz123
    sackingz123 What's a Dremel?
    7 Feb 2007
    if you lookin for a cheap am2 mobo. ecs geforce6100sm BABY!!
    <-------overclocked 3800x2 and still running... :rock:
    too bad it has only 2 ram slots :sigh: ..
  9. axscpu
    2 Jun 2006
    one of the reason beside the memory issue with the gigabyte, is that the 6100 does not do hd acceleration while the 6150 does.... this pc is not going to be overclocked but it will be an htpc, so the tight timing is just for speed actually and not for overclocking...
  10. axscpu
    2 Jun 2006
    just receive the abit motherboard but I think its broken because to start it up I have to press the power button eight to ten times until its starts up... is this normal on this motherboard or is there something wrong with my settings, im using the kingstons hyperX khx6400d2llk2/2gn which are low latency cas 4 at 2v, but spd is cas5.... so any sugestion?????
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    If you're having problems with hardware, always try default settings before concluding something is broken.
  12. BUFF
    25 Mar 2005
    things to check are the PSU & the memory timings/voltage actually set by the board.
  13. axscpu
    2 Jun 2006
    tested it with three diferent psu and four diferent pairs of memory... the thing is that with ddr2667 it doesn't even start up, so went back to the store and replaced it with a gigabyte which was much cheaper and will think about a video card for this machine... thanks so much for the help guys..... and abit has lost a customer :(
  14. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    I have the M2NPV-VM Mobo. Class board. Best as far as i am concerned. OnBoard graphics are ace.
  15. polished skull
    polished skull mini modder
    7 Aug 2007
    have you guys heard about TA690G........?
    i heard that its great for overclocking..
  16. Cat_J
    Cat_J What's a Dremel?
    13 Oct 2007
    I've never used an Abit board that I thought to be anything above average and I've seen many break so I wouldn't use them either. Back in the day I used to use MSI who were reliable, just not many features. Now I swear by Asus though as they've been nothing but great.
    I was going to try a Gigabyte but they're so ugly and I have a window in my case, shame really as they're supposed to be good but I'd have to look at it.
