Graphics Best bang for the buck card out there right now.
Discussion in 'Hardware' started by MSTRKRFT, 5 Dec 2009.
  1. MSTRKRFT
    MSTRKRFT What's a Dremel?
    5 Dec 2009
    Hello there, long time lurker first time poster.
    I'm looking for the best bang for the buck video card out there right now.
    Purpose: Gaming.
    Budget: ~$160 (I'm in the states).
    One thing I wanted to run by you guys.... My current PSU is generic (~550W, with no PCI-E 6 pin power connector, so the card would have to come with a 6-pin to molex adapter), would this kind of PSU be able to run today's video cards?, I'm talking about mid-range cards, not 5970s or GTX 295s...
    Specs:
    E5200 @ ~3.6
    4GB DDR2
    GIGABYTE GA-G41M-ES2L
    Samsung P2070 @ 1600 x 900
    Thanks a lot!
  2. Elton
    23 Jan 2009
    The HD4890. That's the only thing aside from the HD5770(which you'll have to overclock anyways to get good performance) that has excellent performance.
    How is there a 550w PSU with no PCI-E 6pin anyways?
  3. reggie50
    reggie50 Minimodder
    24 Apr 2009
    You may want to check the amps provided on the 12V output of the power supply. Generic PSUs tend to push the ampage on the lower voltages to achieve the wattage. I'm not sure what it would need though.
  4. MSTRKRFT
    5 Dec 2009
    I really don't know.
    It came with the case.
    Does the HD 4890 uses 2 6-pin power connectors?
  5. stonedsurd
    11 Mar 2009
    +1 to what reggie said. You should be more worried about what your PSU will do to an undoubtedly power-hungry $190 card.
  6. MSTRKRFT
    5 Dec 2009
    That info should come in the back of the PSU no?
  7. stonedsurd
    11 Mar 2009
  8. dec
    dec [blank space]
    10 Jan 2009
    5770 or 5750 if you cant find a 5770.
    +1 to reggie
    itd suck to connect the card and get a puff of smoke when you hit the power.
