Motherboards Best board for over clocking i5 4670k
Discussion in 'Hardware' started by crazymo, 12 Dec 2013.
  1. crazymo
    crazymo What's a Dremel?
    10 Feb 2013
    Any suggestions I was thinking of the GigaByte Z87 D3HP.
    Also any suggestions for Ram is 8Gb sufficient for gaming or should I go up to 16GB
  2. Cei
    Cei pew pew pew
    22 Mar 2008
    8GB is certainly sufficient right now, but it depends on pricing on the day you purchase. If 16GB isn't much more you may as well get it. However, another route would be to buy 2x4GB sticks today and add another set at a later date.
    As for OC'ing, I personally recommend ASUS' Maximus boards. Rock solid and excellent performance.
  3. Si_the-dude
    Si_the-dude Techaholics Anonymous. 0 days clean
    17 Dec 2012
    Hey buddy. In my experience with a few of the Z87 boards I've used, the board itself doesn't make a huge difference and is largely down to budget and personal preference. While some boards will enable you to get better overclocks due to things like better voltage regulation, the overclock you'll get on your chip is mostly down to the chip itself. What sort of budget did you have in mind, what were you going for style wise, and does it have to be a particular size?
  4. Shirty
    18 Apr 1982
    Agree with Si - assuming you're not looking to wring the life out of your chip with a bleeding-edge overclock, and are just aiming for a nice stable daily speed, then any Z87 board will see you right, so just pick the one with the best reviews in your price point, or if you're after specific features then let those guide your choices.
  5. crazymo
    10 Feb 2013
    Tks guys budget @100-120 pounds just want modest over clocking with usual features Asus seems to be the best review wise
  6. Si_the-dude
    17 Dec 2012
    ASUS make great boards. You can pickup a good MSI gaming focused-board like the Z87-G45 in your price range if you shop around. I believe Gigabyte has just introduced a modestly priced ATX version of their Z87 Sniper board which is another gaming focused board. You'll struggle to go wrong with it to be honest dude, so don't worry about it too much :D
  7. crazymo
    10 Feb 2013
    What sort of cooler would you recommend budget @ 40 pounds
  8. docodine
    docodine killed a guy once
    10 Feb 2007
  9. crazymo
    10 Feb 2013
    Is it as big as it looks and easy to fit. I have only ever used a stock cooler
