Windows Best CAD software? (preferably free)
Discussion in 'Software' started by RasmusAnden, 17 Nov 2008.
  1. RasmusAnden
    RasmusAnden What's a Dremel?
    28 Feb 2007
    Hi guys :)
    i'm thinking of a casemod, and need to make some circuits for it. however i don't have any CAD software.. and since i've never used one before i have no idea about what features and so on, is required/good to have.. SO, i was thinking that some of you guys had any suggestions for a good CAD program. ;)
    I would prefer, as it says in the title, that its free, however i don't mind paying a bit for one :)
    Rasmus.
  2. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Google sketchup is free, I dont have any experience with it though as my Uni proves Autodesk Inventor which is brilliant but very expensive if you have to pay for it.
    There's also the sketchup component repository which should mean that you dont have to model standard components.
    Moriquendi
  3. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Another vote for sketchup, especially as sketchup pro lets you export to autocad files...
  4. RasmusAnden
    28 Feb 2007
    Think i explained it a bit bad.. cause i need a software for designing electronic circuits. ;)
    and i can only agree with you guys SketchUp is great! :D
  5. Krikkit
    21 Jan 2003
  6. RasmusAnden
    28 Feb 2007
    i did search.. guess i just didn't do it good enough.. my bad :p
    but thanks for the reply :)
