Games I will be playing are: Starcraft Warcraft III World of Warcraft CounterStrike CounterStrike: Source UT2k4 I'm thinking of getting an FX5200? Try to keep it as cheap as possible. I don't nessesarly want to play them at highest settings. this is basically going to be a tamparary card for a fe months until I save up more money.
the ultra will cost. If you can get a 5700regular for cheep or in the very least find a 128bit 5200 as the 64bit one is totaly cripled.
Honestly, if its only temporary, I'd look to get a used card, you could probably get one twice as powerful for the same price.
How about this? Yes its a g4ti 4200 but it will perform better than the 5200 and its about 80bux Or this one Yes its a 5200 but it is 128bit so it should give you better performance.
what about a radeon 9600 pro / xt, it shoul outperform most of the cards mentioned here except the 9800 pro
Club 3D Radeon X300 256Mb DDR - I think that this card is good. (I have no experiences of it, but it sounds good) The prize of this card is ~150 EUR in Finland. I have now GeForce 4 Ti 4400 128Mb graphic card and I have 100 FPS in CS 1.6. Not tested in Doom3 or CS:S Beta.. UT2004 worked also well. This card cost 200 EUR about 2 years ago when I bought this..
I'm looking for something < $70 Currently I'm thinking about this - http://www.newegg.com/app/viewproduct.asp?description=14-145-042 REmember it's jsut temparary... =\
I am buildinga new computer, my mobo has PCI Slots open and an AGP 4x/8x slot.. the video card is the only thing I do not have atm.
