Cases Best case under £80?
Discussion in 'Hardware' started by ltlukelt, 16 Oct 2010.
  1. ltlukelt
    ltlukelt What's a Dremel?
    2 Oct 2010
    Hi,
    I'm looking for a case under £80 that will hold a GTX 460 and an i5 760, both of which I will be overclocking. Cooling is of importance here, but I dont mind how loud the case is.
    I have looked at a few such as the CM 690 II Advanced, as well as the Xigmatek Usgard, HAF 912 and Fractal Design R3 , but I am still completely undecided.
    Care to offer any suggestions?
  2. Guest-56605
    Guest-56605 Guest
    Air cooled I presume?
    For all round build quality and versatility you can't beat the CM 690 II :thumb:
  3. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    It's not a question of which case is best but which case is best for you.
    As you don't seem to care about noise (personally this is one of the most important things for me in a PC) i'd immediately discount the Fractal Design, it's a great case but focuses on great noise-dampening rather than great cooling.
    The CM 690 II is a great all-round case and is highly recommmended by many.
    The Xigmatek Utgard will give you a bit better value for money & the included fan controller is a great feature (I have the Utgard myself).
    HAF 912 seems to be another great value all-round offer but personally I hate the styling of the HAF line of cases.
    You've pretty much picked out the top cases in this category but i'd also recommend you have a look at the Antec 902 which, while being quite old, offers some of the best cooling available.
    thehippoz likes this.
  4. ltlukelt
    2 Oct 2010
    Yes, the CPU will be air cooled ;)
    I quite like the look of the CM 690 II, but I was uncertain on how efficient it is in terms of airflow.
  5. ltlukelt
    2 Oct 2010
    I was considering the Xigmatek Utgard as well. How good is it in terms of cooling?
    I've read that the 902 can quite cramped?
  6. Telltale Boy
    3 May 2010
    You can see the cooling performance of all three in Bit Tech's 912 Plus Review.
    They also mention that they don't particularly notice any lack of space in the 912. All the cases suggested are mid-towers so are going to have a similar amount of space inside.
  7. ltlukelt
    2 Oct 2010
    Thanks for the link.
    In my opinion, it is now a decision between: Xigmatek Utgard, Antec 902 and CM 960 II.
  8. ltlukelt
    2 Oct 2010
    After some consideration, I have decided it is now the CM 960 II or the Xigmatek Utgard.
    Does anyone have any experience with these?
    Also worth a mention is that I will also be using a Titan Fenrir as my CPU cooler. Will this fit into both?
  9. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    Yes both cases will fit the Titan Fenrir.
    I have the Utgard and I must say it is a very nice case although they are both very similar in terms of cooling and design. If I were you I think looking at the price points, and general pictures of the case would be the best thing. :thumb: Here are some links:
    Xigmatek Utgard
    On scan..
    Bit Tech review
    Xigmatek website
    CM 690 II
    Coolermaster CM 690 II Lite
    Coolermaster CM 690 Pure
    Coolermaster CM 690 II Advanced
    The Coolermaster CM 690 II Advanced is the best cm 690 ii by quite a chunk.
  10. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I have a Coolermaster CM 690 II Advanced and I think it's an awesome case. Comes with 3 fans, but there is room for so many more. Like another 7 or 8 fans can be fitted about the case. That's a lot of potential airflow.
    Personally I just added another 140mm fan in the floor of the case as an intake to balance the airflow out a bit.
  11. Guest-56605
    Guest-56605 Guest
    I've had both, the CM690 II edges it with the hard disk dock :thumb:
    Secondly some of the lads on here have had problems with the fan controller panel heating up to one degree or another which is cause for concern, it may be a stray batch but is something to bare in mind none the less.
  12. ltlukelt
    2 Oct 2010
    Thanks alot guys!
    I'm now swaying more towards the CM 960 II Advanced, being as it has great cooling potential, and that outside dock would come in very handy :thumb:
  13. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    Personally, if it was my £80, i would go for the lovely Lian Li pc-60fnwb
    Lian Li cases are really well made. This one looks rather good and I love the side window. You can also get a nice aluminium cover for a dvd drive that fits in well with the case.
    As for HD docks. How offten do you change a hard drive? also changin a hard drive in a case like this only takes a couple of minutes.
  14. Fizzban
    10 Mar 2010
    With a dock you don't need to change anything. Great for if you got a spare and want to back something up or take it to a mates house. Or if a mate comes round with some goodies to share on his HD. 2 seconds it's in. Rather than faffing about turning the machine off and taking the side off and taking a disc out to make room and FAFF,FAFF, FAFF.
    The LianLi is nice naturally, but its insides are silver. I look at cases which have silver inside now and they just look wrong..even polished alu looks lame compared to a case that is all the same finish.
    Also 690 II Adv looks better than the Utgard and if you actually want/need a fan controller you are better off buying a decent one yourself IMO.
  15. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Im waiting on my CM 690 II to arrive :) can't wait looks an amazing case for the money.
  16. ltlukelt
    2 Oct 2010
    Best case for £120?
    As I'm now getting an i3, my budget for the case has increased to £120, preferably £110.
    I've been looking at the CM Storm Sniper here. Has anyone used this case or can recommend an alternative under £120?
    Thanks.
  17. Telltale Boy
    3 May 2010
  18. ltlukelt
    2 Oct 2010
    Thanks for the link. Looks like a fantastic case, although it's a bit outside my budget at the moment :(
  19. Telltale Boy
    3 May 2010
    I'm confused? That case is £100, less than the £110 you specified.
  20. ltlukelt
    2 Oct 2010
    £100? Everywhere I've looked its £140!
