Storage Best config for SSD and HDD setup
Discussion in 'Hardware' started by Flak, 15 May 2011.
  1. Flak
    Flak What's a Dremel?
    11 May 2011
    I am getting a new system with a Corsair force 120Gb SSD and a 1Tb Samsung spinpoint F3 HDD. Can you advise me on the best usage of these drives with regard to what to load on the SSD verses the HDD?
    My initial thoughts were to use the SSD for Win 7, Photoshop and Office 2007 and the HDD for everthing else. Am I thinking along the right lines here or should I be doing something else?
    Thanks for your help.
  2. IronDoc
    IronDoc What's a Dremel?
    7 Apr 2011
    You'll fit a lot more than that on the SSD surely? I would think you'd get most of your programs on.
  3. Torin
    Torin What's a Dremel?
    8 May 2011
    i believe your initial thoughts are right
  4. snooky32
    snooky32 What's a Dremel?
    29 Apr 2010
    Indeed I'm sure you can fit a lot more than that on a 120gb ssd. I fit all my applications on my 128gb ssd, along with a handful of games that I play regularly.
    You can also use Steam Mover (http://www.traynier.com/software/steammover) to move any installed programs between drives without reinstalling etc.
  5. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    You definately will be able to fit more than that on your SSD.
    I've currently got just windows 7 installed on mine and its just using over 10gb with a few tweaks. Along with BFBC:2 I've only used 20gb of my 64gb ssd.
  6. Flak
    11 May 2011
    So, am I right in thinking that installing programs to the SSD is the correct idea, and using the HDD to keep all the rewritable data on? For example word and excel files, documents pictures videos and downloaded items?
  7. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    yes that would be correct. i recommend using audit mode during install to create junction points for \users, \programdata, to point to your hdd. it's nice for transparency during usage and ensures temp files are written to hdd instead of ssd.
  8. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Can you not only use audit mode when first setting up windows? Got an idea of making a custom windows rom file now with all my basic install stuff on it hmmh.
  9. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    I wouldnt mind a little expansion on that too- you can only run audit mode once when you initially install the OS, but, since I am in the process of buying an SSD and new HDD a guide for relocating \users & \programdata would be nice ( even a link to a guide )?...
  10. IvanIvanovich
    31 Aug 2008
    see here. yes you can only use audit mode during install. you can still move things afterwards, but it involves creating a new user account and deleting your old one if you want to relocate everything. you can also do it via a bunch of regedits, but i don't recommend.
    [edit] actually never mind that last, check this guide to move after installation.
    SuicideNeil likes this.
  11. SuicideNeil
    17 Aug 2009
    Cheers dude, much appreciated.
  12. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    this is how i did it step by step
    How to change folder locations.
    Step1: open ‘My Computer’
    Step2: open ‘C:’
    Step3: open ‘Users’
    Step4: open {username}
    Step5: right click on ‘My Documents’
    Step6: select properties
    Step7: select location tab
    Step8: select move button
    Step9: locate the drive you want to move it to, and create a new folder called ‘My Documents’
    Step10: highlight the new folder, and click select folder
    It will ask if you want to move the contents to the new folder say yes and your away.
    just repeat the above steps for each folder you want to move
  13. BitHeroes
    BitHeroes What's a Dremel?
    1 Jun 2011
    I've found with games that there isn't much benefit from running them off SSD apart from a handful of games such as World of Warcraft. Most other games I've tried tend to load as fast as an SSD, or only a tiny bit faster.
  14. Flak
    11 May 2011
    That was the process I followed, except that I created the new folders on the HDD first. the rest of the process was the same as above except that now when I open libraries I seem to have two identical locations on the HDD!
  15. IvanIvanovich
    31 Aug 2008
    this is why junction points are preferable.
  16. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    Why move ProgramData? It's only a gigabyte or two in most cases. Moving that to HDD would only hinder your application startup speed as the SSD would have to wait on the HDD to load the relevant user settings that have been saved in ProgramData.
  17. IvanIvanovich
    31 Aug 2008
    i didn't personally, but the thinking behind it is primarily for r/w cycle saving. it is basically the same as the all users directory under \users, which has a junction to that anyway. there are a lot of temp files written often to that location. you could argue some of the same about moving the entire \users directory as well. there are some VERY important files located there, like things required for the system to boot. but for ease of use it outweighs the cons in my opinion. if you want to move things off the ssd its just easier to 'move' the directory with a junction that to dick around with each thing separate. but if you wanted to, you could just as easily create a junction for music, documents, video, etc individually. and leave everything else in its default location on the ssd.
    and really it dosen't effect the speed of loading much. maybe a second or two but its still very fast, as it almost works like raid 0 when loading as it will load stuff from the ssd and hdd at once. when i first set up like this i actually had my \users on a sata 1.5gbps disk and it was still fast as hell.
  18. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Junction points are definitely the easiest & cleanest way to do this.
