Cooling best cooling for i7 920
Discussion in 'Hardware' started by fazle321, 28 Mar 2012.
  1. fazle321
    fazle321 What's a Dremel?
    23 Mar 2012
    guys please suggest me good cpu cooler for my i7 920
    its really urgent.
    my idle temperature is exceeding 80c
  2. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    uuhhh budget??
    size restrictions??
  3. Big Elf
    23 Apr 2009
    There's something wrong if idle is hitting 80°C. If you're using the stock cooler make sure all the pushpins are correctly inserted.
  4. rollo
    rollo Modder
    16 May 2008
    what he said
    frio still 1 of the best coolers for 1366 platform ( air )
    or an h60 corsair ( water )
    £30 frio ( requires alot of clearence to fit ( full tower cases only really )
    £55 for h60 ( can fit in any pc )
  5. towelie
    towelie How do I Internet!!
    1 Sep 2011
    As everyone else is saying there something wrong if thats idle and it not OC.
    Mine 930 @ STOCK 2.8 at idle is 35-40 with a corsair H80, what are you using for the thermal read out maybe an error?
    I would make sure the cooler properly seated and maybe reapply some TIM.
    Even if you have a stock cooler should not see temp that high unless your ambient is like 100C....
  6. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    I use a Thermalright Ultra Extreme with a gentle typhoon on it and my idle temps are always around 35-40. Ok so I am not running it overclocked at the mo but still, does the job for me.
    Only problem I have is that the fan overhangs the first memory slot so I am a little limited on upgrading until I change for a smaller/water cooler.
  7. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I use an aging corsair H50 with 2 x akasa apache blacks. My i7 is overvoltaed and clocked @ 3.8 and my idle temps are between 38-43.
  8. Teelzebub
    27 Nov 2009
    80c :jawdrop: I've used a T.R.U.E and the Corsair H70 and a the newer H80 and not even on prime 95 have any of my 17's hit those temps, Definitely something wrong there
  9. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    You running the stock cooler? If so I wonder if one of the push pins are buggered, means there would be F*uck all mounting pressure on the cpu.
    If you have the money go for a Noctua NH-D14, just make sure you don't have tall ram.
    http://www.scan.co.uk/products/noct...er-with-2-x-fans-s1155-1156-2011-1366-775-am3
    or there's the dark rock advanced http://www.scan.co.uk/products/be-q...5-1155-1156-1366-2011-am2-am2plus-am3-754-940
    or if you just want to keep temps under control, and don't want to do any overclocking, but are on a really limited budget, there is the
    Artic Cooling Freezer 13 http://www.scan.co.uk/products/arct...el-775-1155-1156-1366-amd-939-am2-am2plus-am3
  10. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    I think a better cheap alternative would be the Arctic i30 trashcanman :)
  11. thetrashcanman
    18 Nov 2010
  12. mikeyman198
    12 May 2011
    CPC did a review on it and it actually performed better than the Dark Rock Advanced :)
    Unfortunately though, it only supports 115, 1156 and 2011 :(
