Best CPU Heatsink/Fan
Discussion in 'Hardware' started by v0id, 6 Mar 2002.
  1. v0id
    v0id What's a Dremel?
    2 Mar 2002
    I got a thermaltake 6 CU+ - but ive heard a lot of people say its not that great...... what does everyone think the best heatsink/fan is??? and how much cooler would it keep my CPU than the TT6CU+???
  2. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    IMO you can't go wrong with the good old Alpha Pal8045 with a Mechatronics 53cfm. As for how cool it will keep your CPU, you haven't stated how your Thermaltake does and it depends greatly on your case temp. However, I get around 6-8 degrees above case temp with mine! :cool:
  3. v0id
    2 Mar 2002
    i normally get around 38-40 idle, and 44 load on with my TT6CU+... case temp roughly 20-24
  4. jamiesurfs
    21 Oct 2001
    IMO that's a bit too much for that case temp! Your case temps are OK though, and a better HSF should help!
  5. v0id
    2 Mar 2002
    ive got parts comin in the mail right now, so my puter is sittin on my desk in many a part... so i cant check it right now, but if i remember right, thats what it WAS... i also did a few fan case mods since then, and havent gotten to test em, so i'll report u new case temps when i get my parts all installed and such...
  6. jamiesurfs
    21 Oct 2001
    Also, don't forget to use a good thermal paste like ASII or 3 when applying the HSF. It makes all the difference!
  7. v0id
    2 Mar 2002
    w/ the new mb comes along a stick of Arctic Silver 3 :) muhaha good stuff!
  8. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Thermalright SK6 with 60mm YS-Tech fan. Sex on a CPU.
  9. jamiesurfs
    21 Oct 2001
    Yeah, that's another option. I would still go for the Alpha if you Motherboard supports it though! (Mounting holes I mean)
  10. v0id
    2 Mar 2002
    i dunno if it supports it.... i'll check when it comes.... (today or tomarrow)
  11. Guest-16
    Guest-16 Guest
    No way!! /me kicks thermalright crap that crushed my AXIA and raised my temps :mad: :mad:
    Swiftech or Alpha all the way
  12. Will
    Will Beware the judderman...
    16 Jun 2001
    another voite for the Alpha from me :) I get 39 degrees load at 1.85v, so very cool!
    :cool:
  13. RTT
    RTT #parp
    12 Mar 2001
    see sig ;)
    keeps my tbird @ 1.8v @ 1533 @ 42 load, 38 idle :D
  14. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    The original post doesn't say what the CPU is....
    With my setup (as in sig), I get CPU LOAD temps of case temp+19-20C, and the case remains at room temp (22-23C typically).
    The Alpha is very good if you can fit it on your motherboard (many boards don't have room), otherwise go for the Swiftech MCX462.
  15. Fraze
    Fraze Minimodder
    16 Feb 2002
    I'd reccommend the new version of the Thermosonic Thermoengine...dunno what its called tho :( I've got the aforementioned product & my 1.2 TBird idles at a very nice 30*c :D load is around 38*c according to my Via Hardware Monitor
  16. sco0by
    sco0by Mmm pie.
    12 Dec 2001
    A vote for the swiftech MCX462 here :) My xp1700+ is running at 1900+, with an idle temp of 37C, and a case temp of 27C. I took the delta fan off tho as it was driving me nuts! It has a mechatronics on there now - much better :cool:
  17. Guest-16
    Guest-16 Guest
    idle 37?! mine idles at 31 and its a 1.4tbird on the old original mc462!? wot board u running?
  18. sco0by
    sco0by Mmm pie.
    12 Dec 2001
    Im running a Soyo Dragon+ - I thought 37c was quite low compared to some of the XP temps I have seen posted? maybe coz mine is O/C slightly?
  19. craig
    craig What's a Dremel?
    6 Mar 2002
    im runnin a 1.4 athlon with a thermalright sk6 with a delta ontop and my temp is way high, usually around 50c :confused: i cleaned out the heat sink the other day and aplied some fresh artic silver and it took it down to 40 but now its back at 50+ again. im goin to try usin a 60 to 80 fan adaptor next to see if that helps.
  20. bobunk
    bobunk What's a Dremel?
    4 Mar 2002
    i'm running a pal8045 with a duron 900@1100
    idle: 37c
    load: 43c
