Cooling BEST CPU waterblock
Discussion in 'Hardware' started by customh, 5 Dec 2005.
  1. customh
    customh conflagration.
    22 Oct 2005
    I want to know whatyall think the best CPU waterblock out there is. I like the Swiftech storm myself but i want to get the best, so tell me!
  2. infered101
    infered101 What's a Dremel?
    30 Oct 2004
    Wrong part of the forums. THere is an extreme cooling thread ask it in there. OR a mod will probally move this one.
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Storm is one of the best currently being made, AFAIK.
    Cascade SS is amazing too.
    Really depends on the loop, and what your cooling.
  4. customh
    22 Oct 2005
    Im going to start a new thread and figure out all my gear then, cooling that is.
  5. Mister_Tad
    27 Dec 2002
    cascade-SS is what you want, but tough to find
  6. Cybertronic
    Cybertronic What's a Dremel?
    25 Feb 2004
    Storm G5 is what you want really :)
  7. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    A64 bracket courtesy of the coolmiester... :D
    As tad mentioned they are increasingly rare to find; the Storm G5 is nice but a real kick in the teeth in terms of pricing. Failing them get a Swiftech Storm :)
  8. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Full production block. The storm hands down.
    Speciality water block nothing beats the storm g5. Solid silver base and nice product all together.
    If you still like large bore and want cheep with resonable performance the swiftech 6000series and the apoge are decent blocks.
  9. customh
    22 Oct 2005
    Thanks Jag, what is the storm, large or small bore?
  10. Shadowed_fury
    21 Nov 2003
    3/8 or 1/2. Comes with both.
  11. customh
    22 Oct 2005
    Thanks all, just want to know, i dont care if im overcomplicating things, but is 2 loops a good idea if i want to use the cool-o-matics, and if yes, what tubing to use, id like to use tygon because of nothing but good things i have heard about it, but which type of tygon and what size for both loops?
  12. Fibbles
    Fibbles What's a Dremel?
    22 Apr 2004
    Make a 3/8", 7/16" or, 1/2" loop for the CPU only and then a smaller 5/16" (8mm) or 1/4" (6mm) loop for everything else. I'm not sure if the Cool-Matic's are restrictive (I never opened mine up), but if they're anything like the Graph-O-Matic internall;y, they should not be too restrictive to use with the Storm.
    If you're going small bore the G5 is great block, as is a Nexxos XP - it beats the Cascade-SS by a bit, but is beaten by the Storm G5.
  13. jaguarking11
    10 Dec 2003
    Honestly with the storm on there I would not bopther with two loops. The storm is tweaked to perform very well with high flows and lower flows.
    Most of the time two loops overcomplicate things.
    and the storm does come with both 3/8ths and 1/2 barbs hence the tweaking in both higher and lower flows.
  14. customh
    22 Oct 2005
    Im going with jag and fibbles, might as well experiment, if it doesnt work i can use parts on another sytem.
  15. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    I got my Cascade for sale if you want it ?/
    PM me
    morgan.
  16. Top Nurse
    Top Nurse Minimodder
    31 Mar 2005
    I like complicated. :hip:
  17. Shadowed_fury
    21 Nov 2003
    But is it your first time? :worried:
  18. jaguarking11
    10 Dec 2003
    Well then thats your taste. Personaly im contrary to most of the guys around here. I like things simple functional and efective. I like a watercooling system with big old pipes in it and large bore all the way. Hence my current setup of being a 1/2id system being fed through a heatercore and a swiftech mcw5002 powerd by a hydor l30. Check out my sign for my other project (voyager 2.0). Can you say hard line?
  19. Nexxo
    23 Oct 2001
    As Shadowed fury points out, you've been around the watercooling block a few times. This will be customholle's first attempt.
    Complicated is not necessarily better than simple. It is not necessarily even any good at all. The best design and engineering is minimalist: it does one thing (in this case: cooling), does it well, and does it with a minimum ammount of fuss and maximum reliability.
    "In der Beschränkung zeigt sich der Meister" ;)
