Hi, Just purchased a B&D RTX as it seems to hold up better than the dremel 300 I was going to buy, but now need help to choose the right cutting discs. Mainly for use with steel and Alu cases. Looks like the dremel discs fit with it. Thanks in advance.
http://www.dremeleurope.com/dremelocs-uk/product/3194/348/dremel®-speedclic®:-starter-set-and-cutting-wheels/dremel®-speedclic®:-starter-set.
great for anything up to the hardness of steel. They are brilliant and don't wear as quick as the "sand" based ones.... Not so much dusty/sandy debris either.
