Cooling Best Fan Set Up for Enermax ECA 3250
Discussion in 'Hardware' started by crazymo, 10 Jan 2014.
  1. crazymo
    crazymo What's a Dremel?
    10 Feb 2013
    I am trying to figure out the most efficent fan set up for my case
    It has 2 x 120mm on the top, 1 on the bottom, one at the front, 2 at the side, 1 at the back
    My son's thoughts are,( after extensive goggling lol)
    two on top blowing out, bottom side and front sucking in.
    We dont use the back one as it is beside the CPU cooler fan
    As usual your comments would be welcome
    Here is my kit ( Haven't figured out yet how to show this at the bottom of my posts! )
    Enermax ECA3250-B Ostrog Midi Tower white
    VTX3D AMD Radeon HD 7870 Tahiti LE
    Arctic Cooling Freezer i30 CPU Cooler
    MSI Z87-G45-GAMING ATX Motherboard
    Intel Core i5 4670K
    G-Skill 8GB Ripjaws X DDR3 2133
    Evga 500w bronze psu
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    You should use the one at the back - depending on which cooler you have this normally helps run more air through the heatsink. Which is a good thing.
    The front and side you could have as ins and the back and top as outs - though the side in's are not always that important, unless there is a low one that is over the gpu then you could stick one there.
    Edit: yeah with the i30 you want to use the rear fan, have the fan on the cooler pushing towards that fan and have that fan as an exhaust
