Cooling Best Fans for Corsair H50 Push/Pull
Discussion in 'Hardware' started by ./^\.Ace./^\., 3 May 2010.
What Fans are best For Corsair H50 Push/Pull
  1. Cooler Master R4
    1 vote(s)
    3.0%
  2. Noctua NF-P12 Fan
    15 vote(s)
    45.5%
  3. Noiseblocker M12-P
    0 vote(s)
    0.0%
  4. Other
    17 vote(s)
    51.5%
  1. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    I have plans to swap out my Cooler Master V8 for a Corsair H50 but I want to take it one step farther and go with the Push/Pull setup.
    My options are as fallows:
    - Cooler Master R4-L2R-20AC-GP 120mm Blue LED SickleFlow 2000 RPM (Local store)
    - Noctua NF-P12 Fan - 120mm (Farther store)
    - Noiseblocker NB-Multiframe M12-P 120mm Ultra Silent PWM Fan - 2000 RPM (Online)
    I'm also open to other fan options.
    So far I think I will go with the 2 Cooler Master R4 as they are the easyest for me to get.
    *If I don't find a good Push/Pull setup then I will stay with the stock Corsair Push Fan arrangement.
  2. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    Ideally it would probably be either Scythe Gentle Typhoons or Akasa Apaches but out of the ones you listed the Noctua's are pretty decent thought I think they're rather expensive.
    Forget the noiseblockers for rad's and the look of the plastic on those cooler master fans put's me off slightly.
  3. ./^\.Ace./^\.
    7 Jun 2007
  4. Xonar
    2 Nov 2009
    The Scythe S-flex fans arent too far behind the Typhoons, they use a different bearing so they're slightly louder but if that's not an issue for you then they might be your best bet.
  5. wyx087
    15 Aug 2007
    haven't heard of the first one, noiceblocker isn't the best as far as i know. Noctua is known to be the best in air cooling, so i voted for Noctua
    although i am too interested in the best fans for H50, so would you please not dismiss every suggestion straight off the bat.
  6. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
  7. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    +1 for the Scythe Gentle Typhoons
  8. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    Scythe S-Flex on mine and they work fantastic.
  9. Nikols
    Nikols What's a Dremel?
    13 Oct 2009
  10. Nikols
    13 Oct 2009
  11. Wing Zero
    28 Apr 2010
    not if you're using a 4pin PWM splitter like the one i linked. the blue wire is the PWM control wire, thus the fans will vary their speed. was an absolute swine to find before, but they're becoming a bit easier to find. everyone gets them confused with the 4pin Molex connector when you ask for a 4pin fan splitter cable, you got to make sure you search for PWM.
    for example:
    http://www.aquatuning.co.uk/product_info.php/info/p7333_Y-Kabel-4Pin-PWM-auf-2x-4Pin-PWM.html
    http://www.aquatuning.co.uk/product...in-to-2x-4Pin-PWM---1x-3Pin-30cm---black.html
    hope that helps
  12. Nikols
    13 Oct 2009
    Ah sweet, yeah mine is a 4 pin pwm splitter so should be doing it's job then. Cheers for the info
  13. boy_lah
    boy_lah What's a Dremel?
    29 Apr 2010
    I'm a low noise fan so I've bought/used Apache, Gentle Typhoon 1450, Nexus Basic (good Yate Loons) & the Sharkoon Silent Eagles 1000 (non-SE version ie no PWM but otherwise same as the "SE").
    All of these fans are 'quiet' or non-obtrusive fans and I would group them as such:
    Nexus/Sharkoon Silent Eagle 1000 - on par, I like nexus more as it's whisper quiet. Silent eagle maybe a tiny tad more air but ever slightly noisier. When I want quiet, nexus is better. The 'extra' of the sharkoon not worth the 'extra' noise in my books although build quality Sharkoon wins.
    For more ooomph... then it's Apache or GT. Apache has great balance of power/noise. But for all out it's the Gentle Typhoon esp coolers given it's higher static pressure. GT is definitely louder but it's low hum tone means I don't notice it. I only do when I turn off my pc and notice the 'lack of' hum.
    So depending on what you want/need. I would recommend Apache or Gentle Tyhoon for your push pull.
    The 'tone' of the S-Flex fans draws attention to itself hence no no for me although they're v good fans.
  14. boy_lah
    29 Apr 2010
    But most importantly, I now don't go mad on fans after various experimentation... I've reach some of the following conclusions (for myself, my situation anyways).
    - less is more...having a zillion fans could mean disrupted airflow and not necessarily cooler pc/case. side fans/bottom blowing fans often cause this
    - choose between quiet or power. or noise per power. Hence my recommendations above.
    - a slightly positive pressure for me works best... ie. more air in that out. So I then to put a tad more 'powerful' fans in the front of case sucking in... then 2-3 quiet/weaker fans pushing air out.
    - again, simplicity is key for me - buying 2000RPM fans and a controller is messy... cabling and usage. I prefer buying 1000-1500CPM fans and use it as is.
    - finally, as a (very) general rule, 1000RPM is the optimum for quiet fans. 1500 is better power for still low noise. After that, it's noticeable period. But everyone is different. Also the 'tone' of fans is v v impt. GT is great because it's tone is low 'hum...'. Nexus is whisper quiet. Sharkoon is quiet but tone draws attention to itself. Apache is very good alternative to GT although slightly less powerful.
    Build quality Apache is best, closely followed by Sharkoon. GT is good. Nexus is 'budget'.
  15. AsubstanceD
    AsubstanceD What's a Dremel?
    3 May 2010
    +1 on the Scythe Gentle Typhoons, don't know how important the looks are, because I have these hooked up, and noise level and cooling are so impressive.
  16. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Akasa Apache, have one on my Coolermaster heatsink and I still don't know what it sounds like, have never heard the thing since I bought it, and my X2 550 averages at about 27-30 C
  17. FuzzyOne
    FuzzyOne
    19 Sep 2002
    I use two of these on my h50 super silent :thumb:
  18. zpikez
    zpikez mod-pirate
    25 Jul 2009
    im using the stock h50 fan + nzxt fan that came with my gamma case, both of these are pretty much budget fans and the set up works great so i imagine any higher performance fan will be awesome
  19. gcwebbyuk
    gcwebbyuk Dib Dabbler
    16 Feb 2010
    Not using them on an H50, but I have had both S-Flex E and GT 1850s as case fans. If you are concerned about noise, then you may want to try out the GTs as they give off a strange noise, not a normal fan noise. They also make a whine when they change fan speed. I tried them as they had a higher CFM than the S-Flex's at a given dBA, but then switched back to the S-Flexs because of these weird noises they make. I am going to be selling them off soon as I dislike them so much they are back in their original packaging in the spare room. For me S-Flexs are perfect I currently have 5 of them in my case!
  20. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    I used to have 2 Scythe Gentle Typhoons 1450 rpm. They're quite good, but not as good as
    Sharkoon Silent Eagle 2000 rpm with a fan controller.
    Get yourself a £5 akasa fan controller and hook that up to the Sharkoons 2k rpm. They do have better static pressure, speaking out of experience.
