Cases Best for budget
Discussion in 'Hardware' started by AoE, 30 Oct 2011.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Got a budget of £50, looking a case with good cable management solution, fans and heaps of space.
  2. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    http://www.bit-tech.net/hardware/cases/
    You can pick up cheap cases that are plenty roomy in size, but dont expect too many options for cases with any/good fans or great cable management- many lower-end cases like this are cheap for a reason; a good case that is used would be your best bet for getting a quality item.
    Hence, check out the reviews and then go on a rummage around the tubes of the interweb...
  3. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Bitfenix shinobi or a antec 100 are meant to be quite good.
  4. AoE
    4 Oct 2011
    thanks guys.
  5. adidan
    25 Mar 2009
    The Antec 100 is just under £40 at Scan at the mo. I don't think you can go wrong for that money, have a read through the BT review here.
    Seems a good buy for the money, rear and top fans included (AFAIK) and room for 3 more 120mms.
    Hell, it's not the best but I'd plump for it if I needed a case for £50.
  6. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    May I recommend the Zalman Z9 Plus - it's epic for the price of £45.
  7. AoE
    4 Oct 2011
    zalman looks unreal
  8. Blazza181
    19 Apr 2011
    Its certainly a very nice case. My dad uses one. :rock:
  9. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
    Yep i have built in lots of Z9's very easy to build a tidy system in, plus the budget Fractal range are good for the money, better in real life then the pictures do them justice.
    The big one is the Core 3000:
    http://www.quietpc.com/gb-en-gbp/products/pc-cases/fd-core-3000
    Or an Antce 300, as i think the one hundreds look too cheap.
