Windows Best Free Anti-Virus Programs
Discussion in 'Software' started by Erm..., 14 Apr 2011.
  1. Erm...
    Erm... Witty Title.
    27 Jan 2011
    Just builing a new system and so I was wondering which is the best, free anti-virus software ?
    I know AVG have an extremely good piece of software ( I'm using it right now !) I'm just wondering if there is any other programs I should know. Thanks in advance ! :thumb:
  2. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    I use avast on most of my systems except my main gaming rig. Never really come across many issues.
    Could be its not detecting them or I'm being really sensible in what I do.
  3. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    Well I answer like I do in all the other 'what's the best AV' threads.
    MSE
    :search:
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    search
    MSE, AVG, AVAST take your pick
  5. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    +1 for Avast
  6. Sexton
    Sexton Minimodder
    2 Jun 2010
    Avast the best for me. Uses minimal resources, unintrusive and works very well... am yet to have a virus. Used to use AVG until they started releasing their later versions... they suddenly started hogging RAM and was just impractical for a gaming system.
  7. GoodBytes
    20 Jan 2007
    MSE - Microsoft Security Essential
    > non-intrusive
    > Super fast
    > 64-bit version
    > Minimal resources
    > Does not slow your computer boot time nor your computer
    > Won many awards
    > Detects all kind of Viruses, Worms, Trojans, malware, spyware
    > Feels like you don't even have an A/V running
    > Integrated in Windows Update
    > Really easy to use interface
    > All the most important features are in.
    > Free for home users
    This topic was talked a lot about. MSE is the winner from public opinion here on this forum.
    Next time use the search.
  8. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I used to use AVG but moved to Avast.
    Although, I might change back since Avast is getting more intrusive. I recently installed it to a new Windows 7 build, and it installed a status gadget that loaded at startup and proved to be quite difficult to remove.
    I've never heard of MCE but will give it a try.
    What worries me is how GoodBytes calls it unintuitive, lol.
  9. Erm...
    Erm... Witty Title.
    27 Jan 2011
    I'm sorry I about all the other threads ! I looked for another one briefly bit couldn't find one !
    :sigh:
    Anyway, I see its divided between Avast and MSE. I'll have a look at them both !
    Thanks ! :lol:
  10. Zener Diode
    Zener Diode User Title
    13 Sep 2009
  11. adidan
    25 Mar 2009
    Avira Antivir free edition has been my choice for quite some time now. There's a single Avira pop up advert with each update but one click and it's gone. Worth it for the freeness.
  12. GoodBytes
    20 Jan 2007
    AHHHhhhh pineapple! It's a typo!
    What I mean is not-intrusive. There.
    MSE is better then slice bread. I don't like Avira, and I don't like AVG.
    AVG is too heavy, and slows drastically the boot time of Windows... like if it does a virus check at that moment. Really annoying. Since than, and the annoying "buy the pro" ad, made me really hate it. AVG was good in the good old day. Now, it did everything it can to lose what was great about it. Also, it slows drastically my compilation time of my programming project.
  13. Stuey
    20 Jan 2005
    That's what I figured. =)
    Anyhow, you've convinced me to try it out, thanks!
  14. sWW
    sWW Minimodder
    3 Apr 2010
    +1 for avast!
  15. Erm...
    Erm... Witty Title.
    27 Jan 2011
    Most people say Avast, but then Goodbytes says MSE.
    Which one do I choose ! ? :)
  16. Tangster
    23 May 2009
    I changed from Avast to MSE. It's lighter and less intrusive. Not that the latest versions of Avast are very intrusive.
  17. Toka
    Toka Minimodder
    19 Nov 2006
    Avira
    For no better reason than the file scan engine being called Luke Filewalker
  18. GoodBytes
    20 Jan 2007
    I don't know, this is the first thread that Avira wins in vote. The others where all MSE without exception. Well nothing stops you from trying both (not at the same time of course).
  19. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    MSE is really good. Very impressed
  20. RichCreedy
    24 Apr 2009
