Windows Best free spyware removal tool?
Discussion in 'Tech Support' started by Canon, 8 Dec 2011.
  1. Canon
    Canon Reformed
    19 Jul 2010
    Basically, I'm getting **** raped over here by 'System Fix' which has hidden all my folders and files and tells me I have a fatal HDD error.
    I did have some great spyware removal tools but have forgotten them now, any recommendations?
  2. SuicideNeil
    SuicideNeil New Member
    17 Aug 2009
  3. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    you need to run rkill, it will stop system fix from being a bitch. lemme get link..
    http://forums.malwarebytes.org/index.php?showtopic=84616
    see post 4, system fix moves all your things.
    but you need to run rkill, get it on another computer, put it on a stick. plug into infected machine and run it, it will stop system fix, then do a full malwarebytes and it will remove it, you dont need to go into safe mode. restart, do anotehr scan, then restore all your things.
    http://www.bleepingcomputer.com/download/anti-virus/rkill
  4. GoodBytes
    20 Jan 2007
    Your issue is not spyware it's malware.
    Spyware spy on what you do and sends that information to someone, which may or may not include personal information collected.
  5. short1uk
    short1uk Member
    20 Sep 2011
