Windows Best freeware AV software?
Discussion in 'Software' started by Throbbi, 20 Jan 2011.
  1. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Hey folks :)
    Looking for good, simple, freeware anti-virus software which is very light on resources.
    Was using AVG for absolutely aaaages but it slowly got more bloated and resource hungry. Switched to Avast! which was also excellent for a good while but no it also is becoming a litle sluggish.
    Is there anything else out there which is as effective and nicely streamlined?
    Pre-advice thanks ;)
  2. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    I use Ad-Aware... its free... 2nd Avira Anti-virus software.. also free.. and 3rd is more of a spyware destroyer.. its called Spybot- Search and Destroy.. those 3 in combo.. are the best ones i could think of Throbbi.. shoot me a PM to find out where to get them Also they are not resource hoggers i believe..
  3. mike_dowler
    mike_dowler What's a Dremel?
    17 Mar 2006
    MSE? (if you're running windows)
  4. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Your only free choice that truly meets all of your requirements is probably Microsoft Security Essentials (recommended above by mike_downler too). Went through the whole AV malarkey myself, and it was only sorted when this was released!
  5. mrbungle
    20 Sep 2004
  6. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    MSE and Avast are rated highly in the freeware category. Avira, BitDefender, and Panda Cloud are other alternatives, also free.
  7. GoodBytes
    20 Jan 2007
    MSE (anti-spyware, anti-malware, anti-virus) and in 64-bit for added performance (well it's more your HDD limiting things.. but anything that can help.. helps).
    Super easy to use, very light, doesn't slow down Windows boot, doesn't slow down your computer, and it doesn't annoy you.. in fact.. it feel strange, it's like it feels you don't even have an anti-virus installed.
    Super good job.
  8. Throbbi
    10 Sep 2009
    Thanks for all the replies folks :) MSE it shall be by the look of it.
  9. Matticus
    Matticus ...
    23 Feb 2008
    I have been using MSE for over a year and I can honestly say it has not bugged me or done anything annoying across 4 different systems during this time.
    Microsoft really nailed it with this one.
  10. GilesM
    GilesM What's a Dremel?
    24 Jan 2011
    I must also chime in with a vote for MSE. I recently installed it on a WIN 7 64 bit system and find it easy and unobtrusive.
    I was using AVG when I was on WIN XP (I missed Vista altogether for good reasons) but MSE is better than AVG I find.
  11. confusis
    confusis Kiwi-modder
    5 Jan 2006
    I've been recommending MSE since I started using it a few months back when I switched to Win7.
  12. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Microsoft Security Essentials. Its the nuts.
  13. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I use MSE at home, but at work we have to put Avast on customer machines. Though that is up for review soon and i think we will switch over to MSE.
  14. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    MSE + Malware bytes for me
    MSE on Permanently (Very Lightweight)
    Run malware bytes every now and again just to check for various things
  15. Margo Baggins
    28 May 2010
    I just got a license for Mbam, the live protection is great.
    Scanning for malware its good, but sometimes it doesnt pick up stuff that super anti-spyware does and vice versa, and sometimes combo fix picks up things that both of those dont!
  16. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    This. :thumb:
  17. mawkish
    mawkish What's a Dremel?
    29 Jul 2010
    Avast, definitely.
  18. dangak
    dangak What's a Dremel?
    27 Sep 2010
    Spybot S&D, without a doubt.
  19. Throbbi
    10 Sep 2009
    Been using MSE since starting this thread to ask for suggestions and it really is the proverbial dogs. Epic win for Micrsoft this time around.
  20. BRAWL
    BRAWL Dead and buried.
    16 Aug 2010
    Avast!
