A/V Best gaming headset USB or 3.5mm Jacks?
Discussion in 'Hardware' started by Guest-44432, 19 Jul 2012.
USB or 3.5mm Jacks for best sound and surround.
  1. USB
    5.0%
  2. 3.5mm Jacks
    95.0%
  1. Shirty
    18 Apr 1982
    3.5mm all the way for me Simon, but I don't need the mic or surround so I get to spend my money on pure audio quality.
    I was about to start buggering around in photoshop, but I can't be arsed :p
  2. Guest-44432
    Guest-44432 Guest
    My LAPTOP M18X R2 has its built in sound card Creative Sound Blaster Recon3Di THX
    So I'm looking for something that I can just plug and play. Main usage is for gaming on BF3, teamspeak and some music.:)
  3. hamza_tm
    hamza_tm Well-Known Member
    10 Apr 2012
    PC360 is perfect
    perfect
    gaming and music? perfect
    inbuilt sound card? per- you get the idea :D
  4. Shirty
    18 Apr 1982
    Simon, I reckon you should hook it all into the big rig's audio system, add a sub, uprated speakers, mounted mic etc.
    Be f***in' awesome!
  5. Guest-44432
    Guest-44432 Guest
    If I was a owner driver, then I would do just that!:D
    Right, as I only have 3x 3.5mm Jacks, plus the SPDIF, will the PC360 work with the mic? Or is Stereo headset the best option?:)
    Now really confused what to buy:sigh:
    Pookeyhead likes this.
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    Xonar U3 is basically a DG in USB form
    @t_g
    The PC360 is a decent pair of Sennheiser stereo headphones with a mic stuck to it, it connects via two 3.5mm jacks (mic and headphone).
  7. GoodBytes
    20 Jan 2007
    I have the Xonar U3 for my laptop. While not as good as my desktop old X-Fi, it's very close. Considering the size and the low power consumption, let alone price by a large margin, it compensates.
  8. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    PC360 Cheesecake
  9. heir flick
    heir flick Active Member
    2 Feb 2007
    If you have a decent sound card then i would go for jack but if you have cruddy onboard the i prefer usb, just got the corsair vengeance 1500's myself and pretty pleased with them
