Windows Best GTA 4 Episodes from liberty city settings with HD5770
Discussion in 'Gaming' started by marc.knuckle, 24 Jul 2010.
  1. marc.knuckle
    marc.knuckle What's a Dremel?
    19 May 2010
    i have a HD5770 and use a Q9450 CPU with 4GB of PC2-6400 RAM.
    as my monitor is 1920x1080 i wanted to play it at this but it is a little jerky. if i lower it to 1640 maybe, any idea what settings i should apply to the rest of the graphics options?
    cheers guys
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    The settings that give you a comfortable framerate.
  3. marc.knuckle
    19 May 2010
    cheers mate but i was hoping for a little guidance on actual settings
  4. Dannythemusicman
    Dannythemusicman What's a Dremel?
    27 Jun 2008
    For me turning shadows off and detail distance gives the best results, oh and make sure you don't have vertical sync on.
  5. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    Shadows is the most framerate damaging graphic option I've found. Try and stick to the native resolution or it'll begin to look irreparably awful.
    The best answer I can give is this though; mess around with the settings and get a framerate and appearance you're happy with.
  6. marc.knuckle
    19 May 2010
    thanks guys
  7. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    To run my 4870 at an acceptable framerate in EfLC, I had to lower my resolution to 1440x900, turn off shadows and reduce the detail sliders down to about 15 or 20 I think.
    I could run it at 1680x1050 with shadows on, but the framerate dropped too much at night and when the weather changed to rain or fog.
  8. nuc13ar
    nuc13ar What's a Dremel?
    5 Jul 2010
    everything low or off
    details set to
    = 10
    = 15
    vehicle = 1
    definition = on
    vsync = off
    go baseline, then work your way back up...
