Networks Best Homeplug thing?
Discussion in 'Hardware' started by AlexB, 25 Oct 2010.
  1. AlexB
    AlexB Web Nerd and WC Addict
    22 Dec 2005
    Yo.
    I need a homeplug style networky thing - wha's the best ones to go for? ideally with 3 plugs.
    Do they actually work?
    -al.
  2. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I use Solwise's 85mbps PL-85PE and they have been flawless for over 3 years. I have three of them, and they work well, with actual file-copying throughput a bit better than your average 802.11G wireless.
    http://www.solwise.co.uk/net-powerline-av-index.htm
    At the time, they were the best rated available anywhere, although I dunno how their current range compares, as they only do 200mbps models now.
    I have two PCs and a router plugged in; the router homeplug is connected permanently, whereas the two with the PC are in the same extension lead as the PC, which is turned on only when the PC is on.
    The homeplug connected to my PC goes into a Netgear FS116 (16 port 100mb switch) which is mounted inside my PC and powered off a molex -> DC adaptor I made. As mentioned above, flawless and 100% reliable.
    Given the throughput I've got its a bit laborious for huge file transfers however. If I'm taking several gigs off one PC to another, its better to plug PC 2 temporarily into my 16 port switch via a huge network cable, or to use a USB hard drive. The 200mbps models mitigate this issue quite a lot, I just don't copy regularly enough to pay for the upgrade, and I got given the switch for free, so for once in a blue moon, I don't mind :thumb:
  3. AlexB
    22 Dec 2005
    Yeah, this is going to replace a shitty wireless connection. Thanks for the info! :)
  4. bagman
    bagman Well-Known Member
    18 Apr 2009
    i have some orange home plugs and they are great, but i can't find them on sale any where
    but don't buy netgear home plugs i had a pair and they where rubbish they kept on disconnecting all the time
  5. CrapBag
    CrapBag Well-Known Member
    17 Jul 2008
    I use four of the cheapies from ebuyer and they have been flawless so far.
    3 pc's and an xbox 360 hooked up and no problems to date.
  6. brighty22
    brighty22 New Member
    19 Aug 2010
    I've got several of these. They're as reliable as a spanner, but I have never got above 15Mbit/s - think it might be our power circuitry :/
  7. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Don't buy Comtrend.
    They're the company that make the ones BT provide for free, and the first pair we had were OK, but died (they were never very fast in the first place) after a year, and the new model they sent us continually disconnect (and yes, we have set them up correctly, several times).
  8. AlexB
    22 Dec 2005
    Thanks chaps. Ordered some of the Max Value jobbies. It's only temporary, so even if they fail after a few months it's not a huge issue.
    Ta!
  9. Hazchem
    Hazchem Member
    3 Dec 2004
    Thanks brighty. I too am thinking about getting some of these and those max value ones look perfect.
