Notebooks Best laptop for £300-400? Help!
Discussion in 'Hardware' started by MiNiMaL_FuSS, 2 Aug 2006.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Girlfriends after a Laptop, I've never really develed into the world of laptops and notebooks so i was hoping for some recommendations from you guys here at Bit.
    She's looking to spend £300-400 quid, so basically I want the most bang for buck for that kinda cash, open to suggestions.
    Cheers.
  2. airchie
    airchie What's a Dremel?
    22 Mar 2005
    www.europc.co.uk might be worth a look as well as the dell outlet.
    some bargains on both usually. :)
  3. Mortus
    Mortus What's a Dremel?
    30 Sep 2004
    After much looking around for my self mate, most laptops in that price bracket are pretty much the same normally
    Celeron 1.4-1.5Ghz
    256Mb Ram
    DVD+-RW
    Build int Gfx
    14-15" 4:3 Screen
    So you might as well go for the cheapest possible id say.
    If you look on the dixons site and search for this 574020 @ £369 there is a £20 off voucher on the net and if you use an egg card you can get another 10% Discount.
    Good luck ;)
  4. fev
    fev Industry Fallout
    13 Aug 2003
    got mother a 1.8ghz centrino jobby with 2mb cache, 512mb ram 60gig HD for £349
    t'was quite bargainus with the 14" W/s too
  5. Tarff
    Tarff What's a Dremel?
    12 Nov 2005
    Where would that be from, then?
  6. fev
    13 Aug 2003
    pc world, advent
    comes in a sleek black colour
  7. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I think your best bet for laptops in that sorta price range, would be to have a look on sites like the Laptop Shop and Laptops Direct ;)
  8. MiNiMaL_FuSS
    24 Dec 2003
    Laptop Shop looks good thanks mate.
  9. peteone
    peteone What's a Dremel?
    5 Jun 2002
  10. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
  11. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    I got a Toshiba A100 for £379 off dabs.com. Boots up fast, and does the trick for college work and some games
  12. chunkylover
    chunkylover What's a Dremel?
    14 Sep 2005
    i got a samsung x20 centrino 1.6 256mb built in grfx ,wifi,ethernet, 15in scrn for 400 ex vat from makro of all shops
