Cooling Best LGA1366 Coolers
Discussion in 'Hardware' started by Phalanx, 30 Aug 2010.
  1. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Currently I'm running a Noctua NH-D14 cooler, and my idle temps are around the 36 degree mark on idle.
    I've reseated the cooler multiple times and I just can't seem to get the temperatures any lower. I want to OC my i7 920 but I just don't feel I can trust this cooler, so I was looking into other coolers and was considering a few such as the Corsair H70 or the Thermaltake Frio which have both come out recently and performed well in tests.
    I was wondering what your opinions were on a decent cooler, as I want to get a nice low temp before I start fiddling with those settings ;)
  2. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Whats wrong with 36 idle?
  3. Phalanx
    28 Apr 2010
    I dunno. Everywhere I read, people get about 4-5 degrees less with the same cooler, which either leads me to question my ability to mount a cooler properly, or question my general cooling knowledge. It makes me think either I've got a faulty cooler or I'm missing something obvious.
    I'm wondering if perhaps I should replace stock fans.
  4. dazedandconfused
    dazedandconfused generic babble ->
    26 Jun 2009
    To get real low temps then you need to properly water cool. H70 is meant to be better that the H50 (according to maximum pc) so should better the best air coolers (such as titan fenir) but that depends if you trust their review.
    Personally I would water cool before doing any 'major' overclocking.
    Out of intrest what are you aiming for, 3.8, 4ghz etc??
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Using too much TIM perhaps?
  6. Phalanx
    28 Apr 2010
    Fair enough, I'll give this another shot then.
    I might order some new TIM and try that out. Any recommendations?
    Would you keep the stock fans that come with the NH-D14 or replace them with something else? And which direction would you mount it? Facing the back exhaust or facing the top exhaust?
  7. Matticus
    Matticus ...
    23 Feb 2008
    What is your room temperature? People getting 4-5 degrees lower may just be sitting in rooms which are 4-5 degrees cooler.
    Plus idle temps aren't the important ones, what are you load temps? Get something like OCCT and load it up.
  8. Bloody_Pete
    11 Aug 2008
    I've used Noctua fans before, and I dislike them. They're silent, but have next to no performance. I'd replace the fans with Gentle Typhoons, which I did on my TRUE and my temps dropped by 15C!
  9. Phalanx
    28 Apr 2010
    The centre fan is 140mm I noticed. Would it be OK to replace with a 120mm fan?
  10. rehk
    rehk New Member
    21 Feb 2010
    It should be fine as the 140mm Noctua fan has 120mm mounts.
  11. dazedandconfused
    26 Jun 2009
    Both of these posts are usefull. a higher room temp means a warmer OC, also ive used noctua fans (800-1200rpm) on a rad before and to say they were OK is like saying a Christian is a Jew (sorry if this offends you) they are really not up to the task of a thick RAD such as an XSPC RX.
    I now use gentle typhoons which are amazing, push a lot of air (can tell by the lower temps) and arent overly noisy.
    Andrew
  12. Phalanx
    28 Apr 2010
    Fair enough. I'll get to ordering a couple of new fans and some TIM then.
    I was using Arctic Silver 5, but I'm thinking either the MX-3 or PK-1. Are there any others I should consider? Also, is the Akasa TIM remover a decent remover? I want to make sure it's completely clean when reseating this time.
  13. Bloody_Pete
    11 Aug 2008
    I use AS5 and its good :) Maybe your applying too much?
  14. Phalanx
    28 Apr 2010
    Hmm, OK well I'll make some purchases and update the thread with how I get on.
  15. Bloody_Pete
    11 Aug 2008
    Aquatuning have GT's for under a tenner, plus free postage :)
  16. Phalanx
    28 Apr 2010
    I saw that :) However they also have Coolink SWIF2-120Ps (which are PWM-compatible), which I have seen performing stonkingly well in tests. Decisions, decisions...
  17. Bloody_Pete
    11 Aug 2008
    How many fans can it mount?
  18. Phalanx
    28 Apr 2010
    Erm, well it comes with 2. Not tried 3, although I think it is possible.
  19. rojo
    rojo New Member
    28 Aug 2007
    You have one of the best coolers on the market right now. Why don't you just overclock and test what temps you get under load, as those are the temps that really matter?
  20. Bloody_Pete
    11 Aug 2008
    You could get one of each fan perhaps?
