Peripherals best low resistance mouse mat?
Discussion in 'Hardware' started by IvanIvanovich, 10 May 2011.
  1. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    whats the best low resistance mouse mat? i'm looking for one that i could for example lightly poke the mouse and it would keep moving on its own until it fell off the mouse mat. ala the air hockey table. i'd prefer black / grey / white and definitely nothing with 'gamer' graphics. it doesn't need to be enormous, but a little larger than standard office size would be good. also i would like it to be thin so its not noticeable. i'm used to just mousing on my desk surface. but my new desk isn't as smooth as my old one. since its not made of real wood, i can't sand it to a glass like finish. hence my need for a mouse mat. i've got an mx revolution with corepad replacement glides.
  2. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Would a sheet of Teflon work perhaps ( since its designed to be non-stick, though not sure how smooth it would be as such )?..
  3. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Depending on how good the laser is on your mouse... get a thin sheet of glass cut to size and smoothed off and put that on your desk. If the laser is good, and the glass is thin enough, it should pick up the desk surface rather than refract through the glass and it'll be smooth as a babies bum.
  4. Treacles
    Treacles Minimodder
    7 May 2011
