Modding Best Metal to work with
Discussion in 'Modding' started by mutznutz, 15 Jan 2008.
  1. mutznutz
    mutznutz Cos Ive got a beard u label me evil
    18 Nov 2007
    Thanks for all the help you guys are giving me, almost ready to start the project log just need to finalise the designs etc
    My question is ... as my case is so pants I'll be cutting the case (its a steel case afaik) and may need to add some metal work to it
    Does it matter the metal I use i.e. alu or steel and is one easier to work with then the other
    I've done more work with wood then metal at the moment
    Many thanks
    Andrew
  2. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Aluminum is weaker than steel and much easier to work with. It also looks decent without any finishing. Plain steel doesn't really look all that nice.
  3. gnidnu
    gnidnu Beware of the Tofu!
    9 May 2006
    Aluminium is way easier to work with than steel and weighs less. Also keep in mind that steel might get rusty. And bending steel - in case you consider doing that - can be quite difficult. As you have a choice, you should go for aluminium.
  4. Rebourne
    Rebourne New Member
    26 Jul 2007
    Meshuggah!
  5. mutznutz
    18 Nov 2007
    Not a big fan of swedish metal tbh :D
    I've been having a think and I'm going to try the aluminium route, at the end of the day as its a first proper modding it'll probably be pants no matter what I use hehe
    Many thanks y'all
