Motherboards Best MicroATX Mobo for AMD A10-7850K?
Discussion in 'Hardware' started by simeonipicker, 16 Feb 2014.
  1. simeonipicker
    simeonipicker What's a Dremel?
    18 Jul 2009
    Just a quick question before I purchase the Gigabyte GA-F2A88XM-D3H FM2+
    Is there anything better? I don't know a huge amount amount the AMD chipsets but from my own research looks like A88x is the best and looking at what's out there the GA-F2A88XM-D3H FM2+ tops it?
    Thanks in advance!
  2. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Depends on what your needs are. Micro atx is a given. What about sata III and USB 3? The lower priced boards have neither. The FM2-A75MA-E35 isn't a bad choice either. Personally I prefer Gigabyte boards though. What is your system going to be used for?
    P. S. Change your avatar you thief :)
  3. sandys
    sandys Multimodder
    26 Mar 2006
    I don't know about best but I was quite impressed with the Asus A88XM Plus I have in my daughters machine, at £50 it seems a bargain but I guess it all depends on what you want from a board, it doesn't come with much.
  4. Harlequin
    Harlequin Modder
    4 Jun 2004
    Nael
    tha A75 board don't support the new kaveri chips - you want an A88 based board
  5. simeonipicker
    18 Jul 2009
    Haha! Mine is Kenny "Tux" - The Linux Penguin ;-)
  6. simeonipicker
    18 Jul 2009
    Thanks for all the replies, looking at it the it's between the Asus A88XM Plus and the Gigabyte I mentioned. I tend have a preference for Gigabyte as I've previously had a bad experience of ASUS customer support.
  7. stulid
    stulid What's a Dremel?
    30 Jun 2011
    Stick with the Gigabyte, I've been very happy with my FM2+ board.
