Notebooks Best netbook for £300-400?
Discussion in 'Hardware' started by hitman012, 14 Oct 2009.
  1. hitman012
    hitman012 Minimodder
    6 May 2005
    Hi,
    My uncle recently asked me to recommend an ultraportable laptop of some description for working on documents on the train, plane etc. However, I haven't been keeping track with this sector at all, so I have no idea what's the best model around at the moment. The biggest concern is decent battery life, though a good screen would be nice too.
    Budget is around £300-400 pounds (though obviously lower would be nice if possible!). Thanks in advance for your help :)
  2. Krikkit
    21 Jan 2003
    There's a new batch of Ion-based (fancy new platform, in case you haven't heard of them) netbooks coming in a few weeks. I'm not sure what the battery life is like but they look pretty special.
    hitman012 likes this.
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    If you need one asap, Acer's AO751H is pretty great. Beautiful 11.6" screen, 2GB ram, 250GB hdd, great battery life, yet as cheap as my Eee PC 4G when I bought it..
    Built and designed better as well. :-o
  4. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    As far as I'm aware, the EEEPC 1000HE and Samsung N110 were the leaders back in June. I went ahead and got myself the Samsung, and love it to bits. Both have claims of ~8-9 hrs battery life.
  5. eek
    eek CAMRA ***.
    23 Jan 2002
    Aye, Samsung always seem to come out well in tests. IIRC their strong points include a good battery life and a decent keyboard.
    Hardware-wise they are all pretty much identical and you can easily upgrade the N-series atom to 2GB if it only comes with 1GB. I think the Z-series atom is a little bit trickier as the memory is soldered (it is on the Sony P anyway so I assume it is on others). Saying that, the Z series does offer marginal benefits such as a lower power consumption, and a potentially 'better' graphics platform (for video playback) should Intel be able to write decent drivers for it.
    Ion is clearly going to blow any Intel integrated graphics out of the water, but until some reviews come out I assume that battery life will be sacrificed.
    If you can hold out for a couple of months (maybe less), then the new pine trail platform will be out. This should (in theory) bring better performance at a lower cost. Also, being two chips rather than three, it should use less power (increasing battery life and allowing for smaller chassis to be manufactured).
  6. hotnikkelz
    hotnikkelz What's a Dremel?
    28 May 2009
    samsung nc10
  7. Stuey
    20 Jan 2005
    The N110 replaced that model it and has a larger touchpad and better batterylife if I'm not mistaken.
  8. crosshair
    crosshair It's life Jim but not as we know it
    12 May 2009
    Defo the N110. Just bought one for my wife and it's a great bit of kit. Looks cool too.
    One thing tho', the glossy screen isn't to everone's taste, but it's easy to keep clean.
  9. hitman012
    6 May 2005
    Thanks for all the advice guys. I'll look into the models you suggested :thumb:
  10. hotnikkelz
    28 May 2009
    awesome, i might buy that one myself. My sister has the NC10...but it has one weird problem that she recently told me about, she gets a white screen from time to time.
