Graphics Best nvidia card at 350W
Discussion in 'Hardware' started by 90ft, 9 Jan 2008.
  1. 90ft
    90ft Cheese
    9 Jan 2008
    I have an old machine that only has a 350W power supply.
    I want a nvidia card to replace my ATI card but the new 8 series cards require 450W power to run them.
    Does anyone know what hte best nvidia card is that will run at 350W
    Thanks
    90
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    What video card do you have at the moment? Are you looking for a PCI-E or AGP card?
  3. Krikkit
    21 Jan 2003
    Something like a 7900GS is a good card, whilst still being very low power.
  4. 90ft
    90ft Cheese
    9 Jan 2008
    sorry current card is a :
    ATI Radeon X850XT Platinum 256MB GDDR3 PCI Express W/DVI/TVOUT(OEM)Sapphir card
    which is a bit old.
    I was looking at something like a NVIDIA's GeForce 7800 GTX 512
    but I don't know if I can't get something better in.
  5. Krikkit
    21 Jan 2003
    I wouldn't bother with the 7800GTX, it was surpassed by many cards.
    I think an ATi X1950 would be a good choice tbh. :D
  6. Guest-23315
    Guest-23315 Guest
    Wait and look at the 8800 GS's?
  7. oasked
    24 Aug 2005
    Or get a HD3850. :)
  8. Krikkit
    21 Jan 2003
    I think they're a bit too power hungry tbh, same as the 2x00 AMD/ATi series.
  9. 90ft
    90ft Cheese
    9 Jan 2008
    ATI is a definite no go.
    They don't support OpenGL applications.
    Nvidia does. So I'm only considering them. But power consumption is hte big issue I have.
    I read that the new 8800GT needs 450W , but I also read that it only draws 231W at maximum load.
    So Now I don't know what to believe.
  10. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    The 450W thing is only a suggestion.
    You'll be good if the rest of your machine doesn't draw too much power.
    You could also buy a new PSU, or a new computer if you could afford it.
    :thumb:
  11. 90ft
    90ft Cheese
    9 Jan 2008
    OK I emailed XFX and asked them what was the fastest I could stick in my machine and they have said Geforce 6600 Ultra 128 or Nvidia Quadro FX3400 256MB
  12. Guest-16
    Guest-16 Guest
    If you're considering the purchase of a quite expensive graphics card - isn't there the possibility of upgrading the PSU as well? A 450-550W is not that expensive.
    You'd get away with an 8600 on a 350W I'd imagine, it can't be more power hungry than two 6600 GTs I ran in SLI on an old 350W Enermax back in the day. That was with a P4 in it too.
  13. ryanjleng
    ryanjleng ...
    15 Nov 2007
    the old power supply is no longer operating at 350w. it's actually bit less. voltage can be shaky as well. placing a heavy 80%+ load on an old psu may break it and possibly other things.
    your older cpu-motherboard-ram may make the new and powerful GPU perform like a cheaper cousin.
    give us the pc specs including stuff on psu sticker.
  14. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I Recommend the Corsair VX550 - Fine for an O/C'd Q6600 and an 8800GT...
  15. 90ft
    90ft Cheese
    9 Jan 2008
    OK my machine is a 4 year old:
    Shuttle XPC SB95P V2
    CPU is a Pentium 4 550 3.4 GHz, 800MHz FSB 1MB L2 Cach3(+303.00)
    2GB RAM
    Motherboard · FB95 (proprietary)
    I don't want to upgrade the computer because to be honest it works great. I just need an invidia card to run openGL applications and want to get the best possible so the machine will live a bit longer.
  16. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    i'd say spend a little extra coin and get a new PSU. If you are really on a budget, get one from eBay or smth like that. From what you say, it can't possibly be worse then what you have now:hip:
    As an upgrade for that system, i don't think getting anything above a 8600 is worth the money.
    My advice in a nutshell:
    get a cheap(ish) PSU, and a 8600. You'll spend less then on the 8800 GT, gatting basically the same graphics and a much healthier PC.
  17. Guest-23315
    Guest-23315 Guest
    I built a friends PC that has an Overclocked C2D and 2 HDD's in a P180 with an 8600 GT runs fine on a 430W for context's sake.
  18. Softix
    Softix What's a Dremel?
    11 Jan 2008
    NVIDIA Quadro FX 350 by PNY offers uncompromised performance and programmability at an entry-level price. The FX 350 is the most affordable NVIDIA Quadro by PNY professional graphics board and provides excellent OpenGL acceleration and broad ISV certification. PRODUCT FEATURES: Proven workstation graphics architecture; Advanced vertex and pixel programmability; Full 128-bit precision graphics pipeline; 12-bit subpixel precision; High Precision Dynamic Range Imaging (HPDR) Technology; PCI Express support; Unified Driver Architecture.
