best nvidia graphics card for about £180??
Discussion in 'Hardware' started by mr_ace, 3 Apr 2008.
  1. mr_ace
    mr_ace What's a Dremel?
    4 Oct 2007
    Hi all, building a new pc, and was debating over graphics cards. im definately going with nivida, but i cant decide on what model, and even what brand. so i was hoping you guys could help me out. i'd like one with a pretty good warranty, 1 year at the least. im a fan of evga, but im open to anything. wanting to spend about £180, but that can go up a bit, if its worth it.
    also, while im here, im looking for a mid range psu, something that will run a core 2 duo e6750, the above graphics card and other normal components.
    thanks!
  2. Guest-23315
    Guest-23315 Guest
    Go for an 8800 GT 512Mb , that'll be ~ £130/£140. Then spend the rest on getting half on a DFI DK P35-T2RS.
  3. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    or the 8800GTS 512 if you have a decent motherboard.
  4. mr_ace
    4 Oct 2007
    i allready have the motherboard, a gigabyte p35c ds3r that im going to be using in the build, sorry should have mentionerd this. but did u suggest this for overclocking purposes? i dont really intend on overclocking right away, possibly in the future. also, what specific 8800 gt would you go for?
  5. topdog555
    topdog555 What's a Dremel?
    31 Dec 2007
    I'll 2nd DaveVader, go for a 8800GTS 512 great card for the money
  6. wyx087
    15 Aug 2007
    wait a tiny bit, we may see 8800GTX drop into £180 price bracket. it's currently £190.
  7. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    another vote for the gts 512 here. best deal available right now.
  8. mr_ace
    4 Oct 2007
    thanks all, 512 8800gts it is. what make and model would you recommend?
    also, any thoughts on the psu?
  9. DaveVader
    10 Aug 2007
    PSU: Corsair HX520 or VX450 (or VX550)
    as for the make of the card ... I can't help you out on that one
  10. mctigger
    mctigger What's a Dremel?
    11 Feb 2007
    good model erm... how about this bfgtech one?
    http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=713729
    unfortuantly its out of stock at scan but im sure other places will have it,
    and psu what wattage you looking for? i reckon anything around 500 will cover everything you need and give you some headroom if you wish to oc or add more hard drives etc so how about....
    this corsair 550w vx sereis
    http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=664337
    read some good reviews on it and a good 5 year warranty with it, or if you don;t need as much juice check out this one
    http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=644038
    i use that PSU and its probably the best i have ever used, quiet and very reliable! cables are a good length, however the 4+4pin is a little short inside my p182, so it can be run behind the back panel to the connector, but thats just a minor flaw.
  11. notatoad
    25 Jun 2004
    if you want a transferable warranty get the xfx. if you might step-up, get an evga. otherwise just get the cheapest model you can find. no point paying the factory to overclock it when you can do it yourself for free.
  12. nigelleg
    nigelleg What's a Dremel?
    4 Jan 2008
    Corsair HX 620 would give you a bit of a window for future upgrades
    Just read another great review on the above yesterday it really does seem to be a well made quality PSU
    here is the link
    http://www.hardwaresecrets.com/article/371
  13. wyx087
    15 Aug 2007
  14. noesis
    noesis What's a Dremel?
    3 Mar 2004
  15. wyx087
    15 Aug 2007
    of course. even if you were to get 8800GTS, OCuk's BFG is a lot cheaper than £180 Inno3D. stay with the big brands :)
  16. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
