Graphics Best PCI card?
Discussion in 'Hardware' started by jaaksun, 10 Oct 2006.
  1. jaaksun
    jaaksun What's a Dremel?
    4 Oct 2006
    I've got a decent, but older, computer that needs an updated graphics card so my son can play games. It'll only take a PCI card. What was the best PCI card made before they all starting going Express?
  2. Firehed
    15 Feb 2004
    Your PCI options are incredibly limited... you don't even have AGP? Even the newest PCI cards are going to only marginally better than onboard graphics last I checked. Most power you'll get is around an ATi 9250 or nVidia MX5200; I'd probably go with the former since the nVidia 5-series was largely utter crap
  3. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
  4. Tim S
    Tim S OG
    8 Nov 2001
    The Visiontek X1300 PCI is the fastest PCI video card out there. :)
  5. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    I think i read here on Bit-Tech that there is a x1600 PCI coming or already out.
    Edit: Sorry i am wrong. It was a x1300.
  6. sadffffff
    sadffffff Minimodder
    20 Oct 2003
    so i assume its faster than the geforce 6200 pci (does this only have 64bit memory?)? anyone have any benchmarks between teh two?
  7. Austin
    Austin Minimodder
    16 Jul 2004
    ;) If you're buying PCI (or AGP) rather than PCI-E you can discount anything to do with Hyper-Memory or Turbo-Cache (as these require PCI-E to increase bandwidth). Going by reference clocks they line upa s so:
    GF6200 110nm 300/550 128bitDDR core=1200+225 RAM=8.8GB/s
    X300SE 110nm 325/400 64bitDDR core=1300+163 RAM=3.2GB/s
    X300 110nm 325/400 128bitDDR core=1300+163 RAM=6.4GB/s
    X1300 90nm 450/500 128bitDDR core=1800+225 RAM=8.0GB/s
    :thumb: The GF4MX, FX5200 and Radeons 9000-9250 are pretty old (esp GF4MX) so unless your CPU is very slow and you can get one very cheap you're better off aiming higher. As you can see the X300SE is totally choked by low memory bandwith but the others have enough to keep them satisfied. When you see the raw numbers (which are a decent guide to performance) it's clear why the X1300 is the fastest. Do you have any other options?
  8. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    The X1300 is pretty much unanimously chosen as the best PCI card. I just recommended it to a friend who only had PCI, and he has had good luck with it so far, with some moderate mostly older gaming. I don't think it can be pushed that far though. If you can afford to upgrade the motherboard to AGP or PCI-E you can probably get a cheaper and better GPU with the motherboard for the same price. But if you only want to upgrade the video card, then go X1300.
