Graphics Best PCIe16x for under 170?
Discussion in 'Hardware' started by DMAthlon, 7 May 2006.
  1. DMAthlon
    DMAthlon What's a Dremel?
    7 May 2006
    I need a good graphics card and i'm not looking to pay anymroe than $170 US. pretty much i'm decidiiing between the x800GTO2, the x800GTO Fireblade, and the x850XT..... any other suggestions are welcome. reasoning would be nice as well.
    thanks.
  2. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    The Sapphire X800GTO2 can be reflashed to an X850XT PE. If you aren't good with reflashing or overclocking, go for the X850XT.
  3. DMAthlon
    7 May 2006
    what does the PE mean? versus not having the PE
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    £170? You could pick up a good second hand 7800GT in places. ;)
  5. zinger
    zinger What's a Dremel?
    27 Jun 2004
    PE is Platinum Edition, really it just means higher clock speeds. Most non PE cards can be overclocked to PE speeds. Once it is happy at PE speeds you can normally bios flash a non PE card into a PE card.
  6. zinger
    27 Jun 2004
    I think he means $ not £.
  7. DMAthlon
    7 May 2006
    S**T if i had £170 i'd buy the 7800GT refurbed. sadly $170 equals only like £90 or so.
  8. Tim S
    Tim S OG
    8 Nov 2001
  9. zinger
    27 Jun 2004
    The 7600GS are around that figure also as is the X1600XT. All are good cards, as bigz mentioned the 7600 GT is the one to go for if you can stretch to it.
  10. DMAthlon
    7 May 2006
    damn, i think i will. thansk.
  11. zinger
    27 Jun 2004
  12. DMAthlon
    7 May 2006
    i'd get the second but it's SLI and i dont have an SLI board.
  13. Shadowed_fury
    21 Nov 2003
    No, its SLI-ready. Meaning you *can* use it in a SLI board, but you don't have to.
    Any PCI-E card will work.
  14. zinger
    27 Jun 2004
