Notebooks best place to buy laptop batteries
Discussion in 'Hardware' started by adam_bagpuss, 20 Jan 2011.
  1. adam_bagpuss
    24 Apr 2009
    Hey,
    got a silly acer extensa 5620 with a duff battery. basically doesnt charge much at all lasting all of 5 mins when you take it off A/C.
    had a google around but all the battery website i went to look dodgy as hell, none have phone number to ring, site layout is very similar between sites.
    issue uis battery model is TM00751 @ 11.1V 4000mAh
    but that model appears to be a 14.8V at 4400MaH !!
    i can find the acer model number on any of the compatible lists
    Extensa 5620 1A2G16Mi
    anyone ideas ?
  2. Guest-44432
    Guest-44432 Guest
    Is this the one Clicky or this one Clicky
    Cheers,
    Simon.
  3. adam_bagpuss
    24 Apr 2009
    2nd link is wrong one
    first one is right except del. is 12-24 working days because they are from hong kong !
  4. GoodBytes
    20 Jan 2007
    They are usually are from Hong Kong. Unless you give a call to Energizer or Duracell or Panasonic if they make any. In any case, these companies are unlikely to do a side buisness with the OEM products they are supposed to ship to them. That is if they are genuine. Or it could be someone ordering 200 batteries from the manufacture at a discount and sell it to you, but usually the price is not far off from the OEM.
    Else, it's a company that produces replicated battery cases and install Lithium-ion batteries cell they got. (risky, as you don't know if they use any standard or regulations in installing this explosive battery)
    It's clear that OEM's boost the price of the battery like no tomorrow... it's full of profit... but that's life.
    adam_bagpuss likes this.
  5. adam_bagpuss
    24 Apr 2009
    not prepared to wait 2-4 weeks for a battery to be honest as its an issue now so a UK supplier would be better
  6. GoodBytes
    20 Jan 2007
    If you can't wait, then call Acer.
    If I am looking at the same battery (as Acer follows the battery model, and not the laptop model), so I follow the picture. It's 60$ U.S.
    I was expecting 150$ - 200$ U.S
    Example: http://accessories.dell.com/sna/pro...note_bnrank=0&baynote_irrank=4&~ck=dellSearch
  7. adam_bagpuss
    24 Apr 2009
    had a look at acer which list by laptop model ! not battery model for uk acer store
    £74 but doesnt say if its 11.1V ?
    google the part number it says 14.4V ?
    do i have to match the V ?
  8. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    You must match the voltage. The mAh doesn't matter.
  9. Guest-44432
    Guest-44432 Guest
    This one is UK dispatched Clicky
    Cheers,
    Simon.
  10. adam_bagpuss
    24 Apr 2009
    good lad
    cheers true
    think ill opt for that one.
