Open Source Best registry cleaner for win 7?
Discussion in 'Software' started by trig, 6 May 2010.
  1. trig
    trig god's little mistake
    10 Aug 2006
    any opinions on registry software? preferably free but will consider low-cost options.
    my bios somehow reset and my ram voltages were too low. been crashing for a week. found a program on majorgeeks called little registry cleaner. found 70+ errors and fixed all but 4. those 4 are something to do with activex.
  2. bulldogjeff
    2 Mar 2010
    For a freebie you can't beat ccleaner, that'll remove blighters. And do loads of other good stuff too. That's not a typo it is CCleaner
  3. trig
    10 Aug 2006
    i could have sworn that wasnt compatible with win 7 yet. ill double check. thx for the quick reply.
    edit:
    it sure does. and it was my it buddy at work that said it didnt. shame on him. thx.
  4. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    still haven't seen anything better http://www.yamicsoft.com/
    has everything really and a registry compacter on top of the scan
  5. Bumfluff101
    Bumfluff101 Minimodder
    10 Jan 2010
    +1 for ccleaner
  6. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    Others beat me to it but another vote for CCleaner as you can have an executable only version on a USB stick with no registry entries required, you simply need admin rights on the relevant machine. Very handy as part of the DR/Tweaking kit.
    So far I've used it on every version of XP (including Embeded), Vista and 7 with no problems. UAC doesn't like it, obviously, but the usual "Run as Admin" gets around that.
  7. trig
    10 Aug 2006
    well, when i get home i will give ccleaner a shot at those last 4 errors. if it still doesnt clear them i will try yamicsoft. thx all
  8. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    CrapCleaner... /thread.
  9. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    +1 for CCleaner and Win7
  10. perseadrian
    perseadrian Banned
    12 May 2010
    I think CCleaner - Optimization and Cleaning - it's the best software. I use it, because they release very often new features.
  11. Somatic
    Somatic What's a Dremel?
    21 Apr 2010
    +1 for CCleaner. It gets rid of the majority of obsolete, redundant leftover entries.
    I used to use a lot more registry cleaning software with older Windows, still have RegEditX sitting around though, it adds a nice address bar for registry editing.
  12. Pookeyhead
    30 Jan 2004
    Just to add that I'm another CCleaner user. Great for clearing out temp files and rubbish, and great for clearing redundant registry entries. Never caused a problem here... and it's free.
  13. azrael-
    azrael- I'm special...
    18 May 2008
    You could just open regedit.exe and arbitrarily delete keys and/or branches... :p
    That, or use CCleaner. :)
  14. Steve @ CCL
    Steve @ CCL CCL Tech. Support
    11 May 2010
    Never used a registry cleaner, I get sooooo many calls at work from people who've used em and it's porked windows up something cronic. I'll always go in and manually remove any troublesome keys after backing up the registry first.
    IMO, Windows Key + R > Regedit > End-User who knows what they're doing = Better than any registry tweaker and cleaner out there.
  15. thehippoz
    19 Dec 2008
    yep steve that's true.. that yamicsoft is the only one I've seen on vista that didn't cause me problems.. maybe ccleaner has gotten better but last time I tried it- it took out some keys that adobe needed to run
  16. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    True that.
  17. Pookeyhead
    30 Jan 2004
    LOL... Great if you know what you're doing, but.....
    However many calls you get from ruined systems caused by crap reg cleaners now.. imagine what will happen if the same people try to do it manually?
    I'm sorry, but a GOOD reg cleaner will not ruin anything. I've used CCleaner for ages.. and I run it once a week. No problems.
    It's all about NOT using any old software that happens to come in a Google search without knowing what it does.
    IMO.. if a reg cleaner works.. why would I bother manually tracking down, and deleting keys? I have better uses for my time.
