Modding best rheobus/fan silencer
Discussion in 'Modding' started by SitraAchra, 21 Dec 2002.
  1. SitraAchra
    SitraAchra Minimodder
    28 Sep 2002
    I need to quiet my sassy comp. www.pcmods.com sells the rheobus v 2.0 for $30.00 down from $60.00 awhile ago. Is this the best for the money? What are my other options for multiple fan control?
    Sitra
  2. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    dont like rheos personally, build ureself a PWM controller i think...
  3. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    I'd preferr an Electrobus. Macro did a article on how to make one.
  4. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Yeah i prefer my electrobus to my PWM controler, the PWM stall's my deltas or just makes them screw up!
  5. ChriX
    ChriX ^
    30 Aug 2001
    Thats a Sunbeam rheobus jobbie, looks quite nice and works great. Review here if you're interested. They are $37.99 I think, looks better than the PCMods one imho. :)
  6. SitraAchra
    28 Sep 2002
    i've never heard of a PWM. Will someone tell me or link me to a place that I can find out?
    Sitra
  7. SiMonTiST
    SiMonTiST Minimodder
    14 May 2002
  8. guzzler
    guzzler What's a Dremel?
    14 Dec 2002
    no one makes them commercially, which is strange cos they're by far the best way to efficiently control fans...
    g
  9. SiMonTiST
    14 May 2002
    Yeah, it's definately the most efficient way of controlling motors.
    I mean, ALL speed controllers for motors in RC models use pulse width modulation. (and these motors often draw over 20 Amps :eeek: )
    ::EDIT:: The only problem with PWM is the growling noise you get at low speeds. In high frequency speed controllers (the pulses are much faster), the growling noise is more of a whine, which is much less annoying.
