Cases Best silent PC case? £100 budget for case and fans
Discussion in 'Hardware' started by hurley92, 26 Jun 2010.
  1. hurley92
    hurley92 What's a Dremel?
    26 Jun 2010
    Hey,
    So I have a budget of £100 and seeing as the computer's next to my hifi I need it to be as quiet as possible, and as long as it isn't too warm inside otherwise I don't mine (I won't be overclocking)
    Is maybe the Fractal Design R2 the best one to go for?? Although the heat issue doesn't seem that good, would a couple of extra fans added on help with that or produce too much noticeable noise?
    Are there any other acoustic treatments I can do like use rubber washers on all the screws or anything?
    CHEERS
    edit: oh, and my setup is an ATX mobo (asus m4a79te or something like that) with a phenom ii 955be and an hd 5770
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I think you may have answered your own question. The Fractal and a couple of good silent fans is going to cost around £100:
    http://www.scan.co.uk/Product.aspx?WebProductID=1120268
    http://www.scan.co.uk/Products/120mm-Sharkoon-1000-Golf-Ball-Quiet-19-dB(A)-Case-Fan-367-CFM
    The hard drive mounts on the Fractal case already have rubber grommets to dampen the HD vibrations and the Sharkoon fans above come with rubber mounts.
    To be honest, this sounds like the best bang for buck based upon your requirements.
  3. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
  4. andrew8200m
    andrew8200m Modder
    4 May 2009
    Just dropped in to recomend exactly what's just been said and as others have pointed out, you have just about answered your own question there.
    Andy
  5. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    to offer an alternative choice, though there's not much difference between the 2. there's the Antec P183
  6. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Fractal
    /thread
  7. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Xigmatec Utgard
  8. Telltale Boy
    3 May 2010
    I have the Utgard & it's a great case for the price (I love it!) however it's not really wat the OP is looking for here. It has very little of the sound-dampening features that the Fractal Design R2 has so does not really fit his requirement for a silent build.
    Yet again it would help if you expanded on your point.
  9. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    this
  10. Guest-16
    Guest-16 Guest
    Fractal R3
  11. Jokaz
    Jokaz What's a Dremel?
    24 Apr 2009
    And with the extra fans you can always tweak their speed to reduce any noise too - makes a noticable difference with my sons Fractal-R2 and sharkoons
  12. Telltale Boy
    3 May 2010
    As the fan controller that comes with the case only supports three fans you might need to use something else to control the other ones. Either get a splitter cable on the fan controller, get an extra fan controller, or if you enough sys_fan headers on the motherboard you can always use these (Asus motherboards can control fan speeds from within the Bios with a piece of software called Q-Fan).
  13. Jipa
    5 Feb 2004
    Motherboards to have fan controllers built in. It doesn't take the four-pin PWM-header to control the speed. You may not be able to control the individual fan speeds too precisely, but for me the BIOS-settings have always been all I need.
  14. Telltale Boy
    3 May 2010
    Do motherboards still use any other types of fan headers? I was just wondering that there might not be enough fan headers on the motherboard depending on how many extra fans he wants to buy.
  15. memeroot
    memeroot aged and experianced
    31 Oct 2009
    there are quieter cases out there
  16. Fingers66
    30 Apr 2010
    I think you will be hard pressed to find a quieter case than the Fractal for the same price.
    July isn't it Bindi?
    Apart from the new colour choice, reset button and new motherboard tray covers, what else has changed?
    It would be nice if the hard drive bay/rack could be split to lose half the drive bays - it would allow better airflow coming in - maybe a mod in waiting...
  17. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Do we (and by that I mean "you" ;)) have a date on this yet? I'm very, very interested!!
  18. Guest-16
    Guest-16 Guest
    Don't know, haven't heard much since Computex tbh. Best keep an eye on their site.
  19. okenobi
    3 Nov 2009
    Fair play. As there's zero indication of anything there, I may give up waiting. Given your comments about upgrade paths the other day, it might be better to just decide on the R2 and move on the next component I can agonize over for ages.
    Just quickly, I'm assuming the CM 690 II is not a worthy alternative given the title of this thread?
