Graphics Best single card solution >$300
Discussion in 'Hardware' started by customh, 7 Mar 2006.
  1. customh
    customh conflagration.
    22 Oct 2005
    I have 3 picked out, all from different generations. All nvidia too. Im not much for knowing about ATI at the moment so thats why i didnt pick any out. It needs to have dual dvi, pcie x16, and 256 megs of memory (dedicated). Suggestions on which way to go?
    Heres the ones i have picked out
    7800GT
    http://www.newegg.com/Product/Product.asp?Item=N82E16814130256
    6600GT
    http://www.newegg.com/Product/Product.asp?Item=N82E16814150099
    7300GS
    http://www.newegg.com/Product/Product.asp?Item=N82E16814150128
  2. Deathrow
    Deathrow Minimodder
    30 Jul 2005
    7800GT hands down there.
  3. customh
    22 Oct 2005
    Only issue with the 7800GT is that it is a little pricey, i was going to say 200 tops but i saw that was 280 so i thought id up the max price it to put it in the mix. I was leaning toward the 7300GS since this will have 2 gigs of ram. Does ATI have a better solution? Or do their drivers suck bad enough that i should just go nvidia?
    Found these too, any good?
    X800GT
    http://www.newegg.com/Product/Product.asp?Item=N82E16814131420
    X1600XT
    http://www.newegg.com/Product/Product.asp?Item=N82E16814127197
    X800GTO
    http://www.newegg.com/Product/Product.asp?Item=N82E16814131424
    Another X1600XT
    http://www.newegg.com/Product/Product.asp?Item=N82E16814161160
    6800GT
    http://www.newegg.com/Product/Product.asp?Item=N82E16814121192
  4. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    Wait a week for the expected launch of the 7900 series, see what they're like and what it does to prices.
  5. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Have to agree with Bladestorm here, even if its only £35, thats about $100 over there.
    (After rip off Britain charges etc)
  6. customh
    22 Oct 2005
    So how much will the 7900's cost, or are you saying wait and get the 7800GT because prices will likely drop?
  7. speedfreek
    speedfreek What's a Dremel?
    9 Nov 2005
    Prices on the 7800s should drop when the 7900s are avaliable.
  8. Sherk
    Sherk What's a Dremel?
    10 Jan 2006
    The 7800 is a great card, 2 of my friends bought it because of my recommendation of it, and love it. :hehe:
  9. customh
    22 Oct 2005
    Still no votes for the 7300 or an ATi card?
  10. Shadowed_fury
    21 Nov 2003
    The 7300 is crap.
    ATi's cards aren't gonna see much of a price drop, unless they try and compete with the 7900s.
  11. customh
    22 Oct 2005
    Well is there a better ATi card than the 7800GT for single card in the 250 ish price range or under?
