Build Advice Best Socket 1366 Mobo and 1600MHz Ram
Discussion in 'Hardware' started by Hamfunk, 12 Jan 2011.
  1. Hamfunk
    Hamfunk I AM KROGAN!
    10 Nov 2009
    I would like recommendation and possibly reference to benchmarks if possible!
    Can anyone explain Asus Rampage boards vs P6T or Sabertooth?
    As you can see from my sig, i have what should be a beast of a system, but, alas, something is holding it back, so i plan to swap parts out (Financial situation dependant) until i find the culprit. Starting with the Ram.
    I have not found a simple round-up of tri-channel DDR3 @ 1600MHz online.... There are so many options with timings and price. Also this vengeance vs. dominator thing is doing my nut in! They have identical specs..... so why the price difference? Would you actually see any performance difference?
    Apologies for the dis-jointed nature of the post!
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Could you explain what exactly is holding your system back?
  3. Sketchee
    Sketchee Suddenly, looters! Hundreds of 'em!
    23 Oct 2010
    And holding back how?
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Want to speed it up? Drop the Raptor. Right now. Get a F3 1TB and a Crucial C300 with a Asus or Highpoint SATA 6Gb/s card. You do NOT need to upgrade or change anything else unless you are having SERIOUS issues :)
    Hamfunk likes this.
  5. Hamfunk
    10 Nov 2009
    Thanks of the responses so far.
    I don't know if 'holding it back' was the right phrase.
    The system feels slow and unresponsive, it takes ages to boot, windows login is slow, it can twitch / hang for a second or two now and again. Fresh windows installs have not helped. It's a niggle thats been eating at me for months now!
    The system i upgraded from was a Q9550 clocked to similar speeds and i knew not to expect much of a performance gain, but it actually feels slower.
    Planning on a crucial C300 at some point soon, but dont want a 60GB, so am saving for a larger drive. I'm personally finding the 150GB on the raptor restricting.
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    just buy the SSD, and see whether you can feel the improvements.
  7. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Sorry, probably some really noddy questions but...
    - Have you downloaded & installed the latest mobo/chipset drivers?
    - Have you updated to the latest bios?
    - Have yo tested your OC for stability and found the right settings
    - Are you running the latest GPU drivers for your SLI setup?
    - Is the PC maintained? (disk cleanups, msconfig startup apps streamlined, defrag etc)
    Apologies if youve already done all these, but thought it might be worth an ask :)
  8. Sketchee
    23 Oct 2010
    As suggested, try just upgrading to the ssd. The rest of ur system shouldn't have issues, i dont think the raptor should be playing up in the ways you're suggesting but it sounds like a hard drive issue.
    I recycled a mechanical drive when i first put together this system, SSD upgrade was fantastic and resolved any issues mine had that were similar to what you're experiencing.
  9. Hamfunk
    10 Nov 2009
    Yes to all of the above! No harm in asking :thumb:
    Ok, cheers for the helpful advice. I'll review my finances at the end of the month and hopefully buy an SSD!
  10. heir flick
    heir flick Minimodder
    2 Feb 2007
    well on paper your specs look fine but if there is a performance issue then it would do no harm to run mem test to check the ram is ok and prime to check the oc is stable
  11. adam_bagpuss
    24 Apr 2009
    your system should fly there should be no need to upgrade anything really.
    id check for issues - if you have alerady done frsh installs then its likely a hardware or overclock issue.
    run memtest
    run seatools for dos on the HDD
    run prime95 and coretemp for overclock
  12. Ph4ZeD
    22 Jul 2009
    Just get an SSD. The difference will blow your mind.
  13. asteldian
    asteldian Minimodder
    13 Jan 2011
    SSD will make loading nice and fast but it won't solve any underlying issues you may have.
    Is the twitch/Hanging random or when you do specific things, if it is at any time I would want to double check your RAM - in Bios are the timings and voltage for the RAM correct? Have you tried just using a module at a time to see if one of them is faulty. More inconvenient but can be quicker than memtest.
